Go to Post We considered naming our 2014 robot "Please Don't Point it at Me". I think the name fits. - KosmicKhaos [more]
Unread 08-02-2007, 09:17
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Gear usage question
Well, so yesterday the order of banebot gears was reopened, meaning that israeli teams will get it 2 days before dead line if we order it NOW. my tream needs 2 gears so its a problem, and we know that the ordering could take up to a month so we dont wanna order the gears due to time isues...
We are considering to build a gear for ourselves, taking the example of last years gears. How legal is that?
ALSO: can anyone please direct me to a diagrtam showing how to make a circuit which feeds 7.2V to the Backup battery making it recharge for the hole time?
Thanks =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-02-2007, 09:37
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Gear usage question
Building your own gear is very legal, and encouraged.
Of course, you probably need a cnc machine.
Maybe you can find a company in Israel that sells gears?
The charger circuit:
http://www.ifirobotics.com/docs/firs...up-charger.pdf
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 08-02-2007, 10:13
AKA: Josh Hecht
http://www.chiefdelphi.com/forums/sh...threadid=53662 suggests not using that charger circuit, though.
Team 694
Unread 08-02-2007, 10:30
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Hey guys about the gears it is perfectly acceptable to make you own gears or bring replacement parts for competition as long as they don't deviate from the original design and there under 25 lbs. Making the gears may not take as long as ordering the gears however in order to make gears you need access to a laser, EDM or the correct gear tooth cutting tool. The gear tooth cutting tool depends on the involute or pressure angle of the gears and a few other things. I will be happy to answer any further questions but if you don't have the correct gear tooth cutter or access to the above named machines your probablly better off just ordering them at this point.
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 08-02-2007, 15:35
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Guys, I think we're dealing with a slight translation issue here. If you read his post a little more carefully I think you'll see he's talking about transmissions.
To Tottanka,
I'm assuming you're talking about the transmissions that came in the kit this year. If you're contemplating building your own transmissions to reduce the speed of your CIM motors or other motors, this is perfectly legal. I would, however, caution you that it can be a very finicky task. Just make sure that you add a little more distance between the gears than just the pitch diameters, as your machining isn't likely to be perfect and it's far better to have a transmission with a little backlash than a transmission with a lot of binding.
Question about Gear-tooth? Nicodemus Control System 4 21-01-2007 02:19
gear question kevin.li.rit Technical Discussion 2 13-01-2007 19:40
Gear Sensor Competition Usage Feedback de_ Electrical 6 15-05-2005 15:15
Mini RC usage question ... MarkVH Rules/Strategy 3 12-02-2005 01:11
Gear reduction question dmellich Motors 6 25-01-2003 08:54
