Go to Post I would like the game to be called Sanity. Just for irony's sake. - Keri Lynne [more]
Unread 08-02-2007, 00:57
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Question on mounting PVC for flag
If our team has a moving arm which is the highest point of our robot, how do we mount a flag which supposed to be 18" higher minimum above our robot vertically at all times??
Can someone provide clarification on this?
Unread 08-02-2007, 01:12
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Question on mounting PVC for flag
That refers to the distance above your robot in its starting configuration, be it 4, 5, or 6 feet.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 08-02-2007, 01:15
AKA: Dr. Brooks
no team (WRRF)
There is no need for the flag to be higher than a moving arm
that swings around. It would be reasonable to mount it so that
it sticks up 18 inches higher than the highest portion of your robot
that does not swing around, so that it is easily seen.
Eugene
Unread 08-02-2007, 08:02
<R15> says, in part:
...The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is a minimum of 18 inches higher than any point on the central mass or structure of the ROBOT (note: ROBOT arms, appendages, and extensions may temporarily intrude into the space above the top of the ROBOT and exceed this height of the FLAG – this a normal part of game play, and will not be considered a violation of this rule).
Note what I have highlighted in red and the part in parentheses.
Unread 08-02-2007, 08:41
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
If you were to mount it in such a way that the arm cannot waste it and it is the highest point without damaging the flag, im sure it will work.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 08-02-2007, 10:28
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
what about if the highest point of a teams robot is their ramps, and they come down at the end of the match, are you allowed to attached the flag holder to the top of the ramp so it will com down with the ramp? or does it have to hold its own at that height?
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 08-02-2007, 11:04
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
http://forums.usfirst.org/showthread.php?t=3445
Q:We have a question concerning the placement of the flag. One of our ideas is to have a large unfolding ramp, onto which we would mount the flag. Throughout the majority of the match, our ramp will be folded up, and is by far the highest point on the robot. When our ramp unfolds in the last 15 seconds of the match, the flag would be lower than the rest of our robot, and would be pointed horizontally. Since this is a temporary condition, only at the end of the match, would this be permissible?
A:No. That would be a violation of Rule <R15>.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 08-02-2007, 11:22
GaryVoshol's Avatar
Cogito ergo arbitro
See this one too: http://forums.usfirst.org/showthread...highlight=flag
Originally Posted by Question
1) R15 says that the flag holder must be permanently mounted to the "central mass" of the robot. Can I assume central mass is any part that does not move or is it any structure that starts the match within the allowed starting box even if it might move and tilt the flag?
2) R15 say that arms and appendages may "temporarily intrude" above the flag. Does this mean that you can start the match within the legal starting box but with an appendage that is well above the flag as long as it is intended to move sometime during the match? My concern is the word "temprorary" since this condition may exist for the majority of the match during scoring when appendages may always be above the central mass of the robot.
Originally Posted by Answer
During the match the flag must remain approximately vertical. If it is mounted to a body part that tilts significantly, then this is not an appropriate mounting point.
The intent of Rule <R15> is that during the majority of match play the flag is the tallest point on the robot, so that it may be easily seen and the alliance assignment of the robot may be easily determined. If an appendage or manipulator spends most of the match higher than the flag, then this is not a "temporary" condition. This would be considered a violation of Rule <R15>, and would need to be corrected before the robot would be allowed to play in another match.
You'll have to build a stationary attaching point so that the flag holder is at least as high as the arm most of the time.
(since 2004)
Unread 08-02-2007, 12:25
haroony341's Avatar
it looks like if we can come up with a way to keep our flag verticalat all times even if it comes down with the ramp. like have the flag holder on a hinge and the bottom weighed down to keep it straight up. that would make it higher that the tallest point of our robot, assuming we are completly flat when the ramps are down. do you think that would be a violation or not?
Unread 08-02-2007, 15:11
waialua359's Avatar
AKA: Glenn
This is still not clear. Even though it says to be 18" higher than the central mass of the robot, it is still subjective due to ramps deploying, moving arms, etc.
Every team technically will have a different design which may dictate the correct height/positioning of the flag.
Unread 08-02-2007, 18:29
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
This seems pretty clear to me. The flag should be above most of the robot most of the time. The holder needs to stay vertical so you don't dump it out on the field.
Remember, this is for identification purposes so think about that when placing your tube.
Wetzel
Viva Olancho!
Unread 08-02-2007, 19:05
waialua359's Avatar
AKA: Glenn
Wetzel
Your reasoning for where it should be placed and the purpose, I understand completely. But based on past experience, inspectors are VERY technical about meeting the rules, even the flag positioning.
However, "The flag should be above most of the robot most of the time" is still vague.
Unread 08-02-2007, 23:30
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We will be mounting it where "we feel is right". If it's not right at the competition, then we'll just simply ask the inspector to suggest a better place. This is why we never somewhat permanently mount the PVC.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-02-2007, 00:29
waialua359's Avatar
AKA: Glenn
The problem for us is that our entire robot minus arm and ramp is only 12.25" above the ground max. If our ramp is deployed and arm moves which is just under 4' in the starting position, it will certainly rotate and move during the match, thus not give our flag a permanent vertical positioning.
Cant see making a 3' extension just for a flag.
We want to put our flag 18" above the central mass of the robot which is right above 12.25," but they may say "NO," it has to be 18 " higher than our 4' starting point, thus forcing us to create a huge "flagpole."
Unread 09-02-2007, 07:02
In your case, I think making a dedicated flagpole sounds like the correct thing to do.
Question on mounting components BQuennell Electrical 7 31-01-2007 12:01
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
[OCCRA]: Rules Question: Can the flag move the arrow? wbhsAndy OCCRA Q&A 1 27-10-2004 11:01
Wave a Flag for our troops! Alex Cormier Chit-Chat 3 25-03-2003 17:57
PVC Question archiver 2000 1 24-06-2002 00:09
