| Thread Tools |
Rating:
Display Modes |
pic: Vex + Roomba = Voomba
Re: pic: Vex + Roomba = Voomba
How are you driving the motors?
If you had a working roomba, this would be a pretty easy way to drive it. Just pass the inputs from the controller through the serial port to the roomba. |
The Roomba even tells you what its sensors are seeing, so you can respond intelligently. And you can even tell it not to override the fall sensors so it doesn't drive down stairs. |
pretty freakin sweet...who would throw out a roomba?
I just bought a discovery off E-bay to do this! I can't believe I got beat to it!
How are you driving the motors with Victors? Your not using the vex motors are you? Maybe I will be the first with a CMUCAM on a Rumba Good work I appoint you skillz points. |
iRobot now has a product called the Create that is basically a programmable Roomba. But it looks like you beat them to it.
http://store.irobot.com/shop/index.j...goryId=2597845 |
#7
Basically I opened up four motor modules and took out the "speed controllers" and then took the leads from the existing motors on the roomba and soldered them to the servo boards, and pluged them straight into the microcontroller.
#8
I got a used discovery for only $40.00 though and I have a pile vex controllers and old 883s.
#9
and what I did to control the motors was just take out the control boards of the VEX motor modules and resolder the leads from the Roomba to them. |
#11
The roomba has a fully documented serial interface that provides access to everything from its motors, to its speakers. The todbot blog has many examples hacked roombas, including a trio of roombas Christmas caroling
| HELP! I just got a Roomba and that's it! | Chuck Glick | Chit-Chat | 13 | 15-02-2007 19:41 |
| pic: Variable Diameter Wheels? In Vex?! - pic 1 | artdutra04 | Extra Discussion | 2 | 07-09-2006 20:53 |
| pic: Variable Diameter Wheels? In Vex?! - pic 3 | artdutra04 | Extra Discussion | 13 | 07-09-2006 17:37 |
| pic: roomba madness @ the boston regional | kborer22 | Extra Discussion | 16 | 30-03-2006 10:28 |
