Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 08-02-2007, 15:11
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Question on mounting PVC for flag
This is still not clear. Even though it says to be 18" higher than the central mass of the robot, it is still subjective due to ramps deploying, moving arms, etc.
Every team technically will have a different design which may dictate the correct height/positioning of the flag.
Unread 08-02-2007, 18:29
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
This seems pretty clear to me. The flag should be above most of the robot most of the time. The holder needs to stay vertical so you don't dump it out on the field.
Remember, this is for identification purposes so think about that when placing your tube.
Wetzel
Viva Olancho!
Unread 08-02-2007, 19:05
waialua359's Avatar
AKA: Glenn
Wetzel
Your reasoning for where it should be placed and the purpose, I understand completely. But based on past experience, inspectors are VERY technical about meeting the rules, even the flag positioning.
However, "The flag should be above most of the robot most of the time" is still vague.
Unread 08-02-2007, 23:30
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We will be mounting it where "we feel is right". If it's not right at the competition, then we'll just simply ask the inspector to suggest a better place. This is why we never somewhat permanently mount the PVC.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-02-2007, 00:29
waialua359's Avatar
AKA: Glenn
The problem for us is that our entire robot minus arm and ramp is only 12.25" above the ground max. If our ramp is deployed and arm moves which is just under 4' in the starting position, it will certainly rotate and move during the match, thus not give our flag a permanent vertical positioning.
Cant see making a 3' extension just for a flag.
We want to put our flag 18" above the central mass of the robot which is right above 12.25," but they may say "NO," it has to be 18 " higher than our 4' starting point, thus forcing us to create a huge "flagpole."
Unread 09-02-2007, 07:02
In your case, I think making a dedicated flagpole sounds like the correct thing to do.
Unread 09-02-2007, 13:12
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
I think that I am confused too. We are building a low center of gravity bot that will max out at probably 3 ft tall. Do we need to put a pvc pipe that extends 4" 18" on our bot or does the flag have to be just 18" taller than our highest point?
Unread 09-02-2007, 14:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
"....top of the FLAG is a minimum of 18 inches higher than any point on the central mass or structure of the ROBOT....."
Sounds to me like you just need to put the flagholder at the highest point on your robot, and the flag will then be as high as the rule demands. The flag is at the top of a 36" tall rod, which fits into your 12" long PVC flag holder tube.
Unread 10-02-2007, 13:46
Thanks that helps me alot. The flag is our last step before shipping. So I have some time to figure out where to mount it. It can be in a corner of the bot correct?
Question on mounting components BQuennell Electrical 7 31-01-2007 12:01
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
[OCCRA]: Rules Question: Can the flag move the arrow? wbhsAndy OCCRA Q&A 1 27-10-2004 11:01
Wave a Flag for our troops! Alex Cormier Chit-Chat 3 25-03-2003 17:57
PVC Question archiver 2000 1 24-06-2002 00:09
