Go to Post Who am I kidding, FIRST is so much cooler now than it was when I was a youngin'! - Michael Corsetto [more]
Unread 03-02-2007, 16:07
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Interrupts with CMUCam
For our robot, we want to use a quadrature encoder so that we can move our manipulator to preset heights on the arm. I read the "Quadratuer Encoders" white paper, and modified the example code to work with one interrupt.
This works fine with the default code, but I noticed that on Kevin's CMUCam code, the use of serial_ports means that user_Serialdrv.c and user_Serialdrv.h must be deleted. Where, then, do I put the interrupt code, and how do I hook the encoder up to the robot controller? I read through serial_ports.c, but I didn't really see a place for an interrupt handler where I could add the encoder code...
Unread 03-02-2007, 17:26
in between teams
AKA: Luke Van Oort
Re: Interrupts with CMUCam
Look at Kevin's encoder code. It supports 8 interrupts for quadrature encoders, and is easily integrated with his camera code.
Team 1219: 2009 - Mentor
Unread 05-02-2007, 15:25
Thank you! This is my first year programming in C, which still makes me one of the senior programmers this year...we're not exactly a rookie team, but a few years ago we lost everyone who knew what they were doing.
The encoders work fine now, and plugging in the camera doesn't give me a code error any more! Now if I could only get the camera to work...
Unread 05-02-2007, 16:08
You might want to try using EasyC. When you program using EasyC, you're actually just creating code that runs with the FRC library that team 190 wrote, WPILib. WPILib is very good at setting these kinds of things up, and you can set up the camera and encoders in just a few lines of code.
If you dont like using EasyC and would rather code by hand, you can download WPILib here and use it as you wish..
http://users.wpi.edu/~bamiller/WPILib/
Unread 08-02-2007, 14:46
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I thought the RC only has 6 interrupts. Where are the other 2?
Unread 08-02-2007, 15:34
in between teams
AKA: Luke Van Oort
That was a typo, six is correct.
Unread 08-02-2007, 23:32
Kingofl337's Avatar
AKA: Adam
Oh good, I'm not going crazy. I was expecting something like, oh well if you use the relay ports and you change this and that boom 2 more.
Game On!
Reading an encoder with interrupts GlennGraham FIRST Tech Challenge 4 25-08-2006 12:44
CMUcam Related Interrupts phrontist Programming 1 31-01-2006 23:01
Help with pots/interrupts mtrawls Programming 10 24-02-2004 17:01
help with Interrupts thoughtful Programming 5 08-01-2004 16:07
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
