Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 08-02-2007, 19:17
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Reading Pan Angle from terminal.c
I am confused as to how to properly read Pan Angle in the terminal.c file inside of auto user_routines.c. Do I define
the Pan_Angle parameter inside of terminal.c or
inside of user_routines.c Do I use an extern static unsigned int statement inside of terminal.c and still
use another statement in user_routines.c? I tried to look
through the code and did not find examples.
1) I have added a statement right below where Kevin is outputting Pan Angle in the print statement to calculate
Pan_Angle.
printf(" Pan Angle (degrees) = %d\r\n", (((int)N_SERVO - 124) * 65)/124);
(Pan_Angle= (((int)PAN_SERVO - 124) * 65)/124);
2) Inside of terminal.c I have added
static unsigned int Pan_Angle = 0;
3) What about inside user_routines.c where I actually
want to be able to read the Pan Angle?
A little confused with C-coding standards,
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 08-02-2007, 20:48
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Reading Pan Angle from terminal.c
If you are declaring the variable outside of a function in terminal.c, make it an unsigned char.
In order to be able to access the variable in user_routines.c, put a
extern unsigned char Pan_Angle;
at the top of the file, outside the functions.
Unread 09-02-2007, 09:11
marccenter's Avatar
Wink Re: Reading Pan Angle from terminal.c - Error Message
So, I have done the following and received the following error message.
Inside of terminal.c I have placed
1) unsigned char Pan_Angle
Inside of user_routines.c I have placed
2) extern unsigned char Pan_Angle
and I received the following error message.
user_routines.c:566:Fatal [151] -internal p opulateExternalReferences() - symbol 'Pan_Angle' is not an external reference.
Marc Center
Unread 09-02-2007, 14:58
mgurgol mgurgol is online now
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Do you have the definition of Pan_Angle defined within a function? Defining it outside of any function in terminal.c will make it global. Define it after the #include statements.
Camera Pan Angle Problem JohnC Programming 3 29-01-2007 12:25
Help needed with finding stud terminal block from KOP amirjpl Electrical 11 25-01-2006 19:32
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
reading negative numbers from a file in VB complete Programming 4 27-12-2005 19:24
Angle from X,Y Astronouth7303 Programming 18 19-04-2004 22:08
