Go to Post Whatever you do, make it idiot-proof. Not because your drivers are idiots, but because the fewer precision maneuvers they have to do, the more awesome driving (and scoring!) they have time to do. - Ian Curtis [more]
Unread 08-02-2007, 16:57
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Re: Team 172 - Electrical Done!
Originally Posted by keericks View Post
Also, I've noticed your 40A circuit supply wire is not directly across the block that houses your positive supply from the 120A breaker. You may want to consider swapping the two wires that lead to your 40A Maxi and the other breaker panel to keep your highest current draws from crossing the "yellow brick jumper" as I call it.
Ah, yes, that hadn't even crossed my mind before now. I will do that.
Thanks!
Unread 08-02-2007, 20:11
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Just remember that current flows through both halves of the circuit - both through the red AND the black wires - so with the knowledge that you should be routing the negative ends back to the Power Distribution Block you now cannot prevent the "jump" across the "Screw Connector Block" because you should only put at most 2 #10 wires in each block. Eh, not that it's going to be a major problem anyway.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 08-02-2007, 20:41
K.,
<R85> Electrical devices must be wired in accordance with Section 8.3 Robot Rules, using
commercially available copper wire for all electrical connections. Aluminum (or other noncopper
material) wire is prohibited. For examples of acceptable circuit designs, please see
the 2007 Robot Power Distribution Diagram.
Please see the revised diagram on the First website.
I am recommending that teams using the jumper, feed the power inputs to the center of the block so that the current divides down both sides of the jumper. This way the current is divided somewhat so that it does not all pass through the entire jumper.
Unread 08-02-2007, 20:44
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
I've just finished re-wiring the 40 amp Victors as per the diagram. All four of them are now routed to the terminal block (and subsequently, the wiring looks a wee bit neater too!)
Thanks for all the input, this would have been bad to miss before the competition!
Team 172 Prototyping K.Porter Robot Showcase 9 16-01-2007 00:28
pic: Team 213 done Daniel Morse Robot Showcase 2 22-02-2006 22:41
pic: Team 56 Almost Done jfischer Robot Showcase 12 18-02-2005 23:41
Team 11 is done! oneeightytwo Robot Showcase 3 09-02-2003 19:27
Team 122 is done! Johca_Gaorl General Forum 39 06-01-2003 20:44
