Go to Post Fans come and go... but if you're a diehard, you stick around during the losing seasons, too. - Amanda Morrison [more]
Unread 06-02-2007, 21:22
937Programmers 937Programmers is offline
AKA: Phil M - Programming Leader
FRC #0937 (North Stars)
937Programmers is an unknown quantity at this point
PWMs not outputting in Autonomous
Hello! I don't know if this question has been answered yet, but I didn't seem to find an answer anywhere.
When we are trying to run autonomous code, PWMs 1-12 aren't doing anything, and the speed controllers that are hooked up into those PWMs are blinking yellow. We think that the PWMs aren't being enabled, but we're not quite sure how to do that in the autonomous code. We have the drivetrain motors in PWMs 13-16, and those are working fine. Nothing else, however, will work.
// If it might be part of the problem, we're using Kevin's streamlined code as a base.
Please help as soon as possible! Thanks!
Unread 06-02-2007, 21:25
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: PWMs not outputting in Autonomous
Perhaps you deleted this line:
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
which goes after Generate_Pwms
Unread 06-02-2007, 21:28
No, that's not the issue. I made sure that I didn't delete any lines when I wrote the code. I just double checked, and that line is definitely where it's supposed to be.
Anything else that might be the problem?
Unread 06-02-2007, 21:41
Mind posting your User_Autonomous_Code?
Unread 06-02-2007, 22:10
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
If you leave the robot in autonomous mode do you get a code error light?
Eric Haskins KC9JVH
Unread 06-02-2007, 23:32
Surprisingly, no. It runs like it's supposed to as I watched the terminal window, but nothing from 1-12 actually runs.
As for posting my code, I'll get to that ASAP. I should be able to get it up tomorrow.
Unread 07-02-2007, 00:21
Jared Russell's Avatar
Taking a year (mostly) off
Blinking yellow speed controllers usually indicate a connectivity problem with the signal...I'm assuming they work under human operation?
Are you calling something that might modify the PWM values before you call PutData()? Try printing out the values RIGHT before you PutData().
Unread 07-02-2007, 13:27
Inverted Inverted is offline
AKA: Eric P.
FRC #1228 (Robo Tribe)
Inverted is an unknown quantity at this point
Send a message via AIM to Inverted
I had the same problem with my motor output during autonomous. I changed the "Generate Pwms" function to his "PWM" function and everything worked. Hope the problem is as simple as that.
Unread 07-02-2007, 13:56
Aaron_H Aaron_H is offline
FRC #1033
Aaron_H is on a distinguished road
Make sure that your PWM outputs are not 127 by default. At the top of the autonomous loop, all the PWMs are set to 127 by default, this may have something to do with it.
Unread 08-02-2007, 19:12
Well, all the motors work under human operation, and I haven't gotten around to messing with it yet today (I just got here )
Anyways, here's my autonomous function before modification today:
void User_Autonomous_Code(void)
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
  relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
  relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
  relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
  relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
		// STEP 1 - Initialize the Camera
		Tracking_Info_Terminal();
		Camera_Handler();
		Servo_Track();
		if(Get_Tracking_State() >= TARGET_IN_VIEW)
			// STEP 2 - Make Robot Face the Light
			if((((int)PAN_SERVO-124)*65)/124 < 0)
				pwm13 = pwm14 = 62;
				pwm15 = pwm16 = 192;
				centered = 0;
			else if((((int)PAN_SERVO-124)*65)/124 > 0)
				pwm13 = pwm14 = 192;
				pwm15 = pwm16 = 62;
				centered = 0;
			else
				centered = 1;
			// STEP 3 - Drive Robot forward until 4 feet in front of Rack
			if((((int)TILT_SERVO-144)*25)/50 < 67 && centered == 1)
				pwm13 = pwm14 = pwm15 = pwm16 = 192;
			if(centered == 1 && (((int)TILT_SERVO-144)*25)/50 >= 67)
				// STEP 4 - Move the arm to the center position
				if(counter < 624 && arminpos == 0)
					pwm08 = 254;
					counter++;
					if(counter == 624)
						arminpos = 1;
			counter = 0;
			// STEP 5 - Place the tube on the leg
			if(arminpos == 1)
				counter++;
				if(counter == 26)
					overdisk = 1;
				if(counter < 208 && clawopen == 0)
					pwm05 = 192;
					if(overdisk == 1)
						counter++;
				if(counter == 208)
					clawopen = 1;  counter = 0;  pwm05 = 127;
			if(clawopen == 1)
				pwm13 = pwm14 = pwm15 = pwm16 = 62;
			// END AUTONOMOUS CODE
	    PWM(pwm13,pwm14,pwm15,pwm16);
Thanks for the help. Hopefully this gets fixed today.
Unread 08-02-2007, 19:49
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
[quote=937Programmers;574561]
In the line when you generate the pwm's, make sure that any pwm that you are using is included in that list. That should solve your problem
Unread 08-02-2007, 20:10
You mean like this?
PWM(pwm01,pwm02,pwm05,pwm08,pwm13,pwm14,pwm15,pwm16);
Or this?
PWM(pwm01,pwm02,pwm05,pwm08);
If we do the first one, then there's an error saying there's too many calls in the argument. The second one doesn't work either because apparently the PWM() function only affects 13-16. I think I have an idea, though, and I'll see if it works.
Edit: Yeah, I didn't think it would. I thought the problem may have been PWM vs. Generate_Pwms, but that's not the issue.
Unread 08-02-2007, 20:35
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
No, the PWM() only deals with 13-16. Try setting all your PWMs to 254 (disconnect any motors first!) and then power up and go into autonomous. Take the PWM cable coming from your Victor and move it up from 1 through 12, and see if the light on the Victor stays blinking orange or if it changes to green or red. If so, then one of your outputs may be bad. If not, switch cables and repeat. I have encountered several bad cables this year. If none of your cables working, switch Victors. The connection from the cable to the Victor is commonly loose on our 'bot this year too.
If none of these work, use the dashboard program (either IFI's or Sean Witte (sp?)) and see if they read 254 or not.
I take it that the PWMs work fine in Teleoperated mode?
Good luck,
Robinson
Unread 08-02-2007, 20:54
Good luck,
Robinson
Yes, the PWMs work fine in Teleoperated mode.
Anyway, using that test, the Victor was blinking yellow from PWMs 1 - 12, but it was green from PWMs 13 - 16, and yet all 16 of them were reading 254, so we think it has to be initialization or something to that effect. Thanks for the suggestion.
Unread 08-02-2007, 21:08
AKA: Robinson Levin
If they read 254 on the Dashboard then I would hazard that it is an electrical problem, not strictly software. Did you use this Dashboard, plugged into your OI, to test?
On last possible test I can think of would be to try this year's FRC plugged into some of the Victors on last year's 'bot. I am assuming at this point that everything else about autonomous work? (eg. analog inputs, digital in/outputs, etc.)
If you happen to be in charge of electrical as well, I'm sorry, but I can't really tell you how to proceed from here, other than maybe trying this year's speed controllers on last year's bot.
Good luck again (it's starting to sound like you need it),
Robinson
Camera not working in autonomous Roger Programming 9 09-03-2006 07:38
Gyro not working in Autonomous? kaszeta Programming 7 11-02-2006 01:28
printf statements do not display in autonomous mode PVC Pirates Programming 3 22-02-2005 15:41
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
