Go to Post "Well-resourced" teams with "deep pockets" don't just spring up, they are usually the result of a lot of hard work. - artdutra04 [more]
Unread 08-02-2007, 17:44
Dremel Drew Dremel Drew is offline
FRC #1800
Dremel Drew is an unknown quantity at this point
light up fan
Is it in regulation to use a LED light up computer fan? The fan lights up blue. So is it permitted? Thanks in advance for your help.
Unread 08-02-2007, 17:54
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: light up fan
Your best bet is to ask the Q&A team that question. They have already said no to this question in regards to replaceing a Victor fan with a lit one. But, that was because the fan on a Victor is considered an integral part of the device.
Unread 08-02-2007, 21:07
Re: light up fan
Drew,
Without seeing the color of the light or the way the fan is mounted in your robot it will be difficult to give you advice. A regular fan on the robot in addition to those mounted on the Speed controllers is allowed under the rules. The light and how it might effect vision systems on other robots would be the question. Inspectors and judges at the event you attend will rule on this critical issue. If you think it might be a problem be prepared for removing it or disabling the light.
Unread 08-02-2007, 21:11
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: light up fan
It is quite likely that you can use it(see above for exception). You shouldn't have problems using it as a fan though since it is just leds on a standard clear fan. But Q&A is by far the best thing to check just in case. Just cause "Someone on CD" said it doesn't mean it will pass inspection.
KK4KQO
http://voltair.us
Unread 08-02-2007, 22:33
Electrical Engineer
Rookie Year: 1995
Re: light up fan
Drew,
Al,
Can you point me to where this is allowed? I see a large muffin fan in the KOP but do not see any allowances for additional fans from outside of the KOP.
Mike
Mike Betts
As easy as 355/113...
Unread 08-02-2007, 22:36
Compnerd's Avatar
Compnerd Compnerd is offline
Self-Proclaimed Nerd
AKA: James H
FRC #1444 (Lightning Lancers)
Team Role: Webmaster
Compnerd has a spectacular aura aboutCompnerd has a spectacular aura about
Re: light up fan
You said the fan led is blue. That could be an issue, because there is the BLUE Alliance, and FIRST could say that it could be a possible distraction... I am not sure check the Q&A
James H. - Webmaster - Team 1444
http://www.first1444.com
If you need any website help send me a PM
Unread 08-02-2007, 22:50
Re: light up fan
Mike,
The Tips and Guidelines make several references to fans and their use. The robot section makes reference to additional components...
<R47> Additional electronic components for use on the ROBOT must be either COTS items, or
assembled from COTS items. Additional electronic components include any object that
intentionally conducts electricity, other than IFI relays and speed controllers, wires,
connectors, solder, and fabricated printed circuit boards.
So as such fans are considered a COTS item and following the flowchart I found no prohibitions.
Do you think they would be prohibited?
Unread 08-02-2007, 23:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: light up fan
Mike,
Judging by that Q&A response concerning hard drives, which stated that they are illegal because they contain a non-KOP motor, it would seem that (apart from the two types of fan in the KOP*), no others are permitted (because they contain non-KOP motors).
Now, traditionally, nobody has really considered the fans to be motors. Indeed, rules like <R91> indicate that motors should be connected to Spikes or Victors, yet historically, fans were allowed to be connected directly to the breakers, and this interpretation is backed up by the current power distribution diagram.
In conventional usage, the fan and the hard drive use their motors for pretty much the same thing—controlling their own motion, rather than the motion of another robot part, yet the hard drive is prohibited. Take it to the Q&A, and see how they balance the competing precedents.
I wouldn't worry about that. FIRST isn't using lights to denote alliance. Avoid green, obviously.
*There's maybe an argument to be made for replacing a kit fan with a COTS fan containing an identical motor (since the motor is a duplicate of a part of a kit item). Ignoring for a moment the question of whether the entire fan is considered a motor (and thus largely unmodifiable), I'd figure that the burden of proof lies with the team to prove that the motor is a clone of the KOP unit—without disassembly of the fan, this is rather difficult, probably to the point of being impractical. Also, since the Q&A considers the Victor fans to be integral parts of the Victor (this is highly debatable, because the Victor could also be viewed as an assembly, but that's the current ruling), their fans would not be considered KOP parts on their own.
Unread 08-02-2007, 23:23
Compnerd's Avatar
AKA: James H
Re: light up fan
Isn't there a flashing light on the robot with the team color?
Unread 08-02-2007, 23:28
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
Re: light up fan
nope, just the signal light. the flags denote team color.
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
2006 light vs. 2007 light compasswilting Kit & Additional Hardware 3 27-01-2007 18:38
red light / blue light ay2b Programming 1 24-01-2007 23:00
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
