Go to Post If there was no internet then somebody in FIRST would probably invent it. - Koko Ed [more]
Unread 06-02-2007, 09:36
WRGibbens WRGibbens is offline
Instructor Materials Fabrication
FRC #1583 (Rambotics)
WRGibbens will become famous soon enough
pic: Ramp Drop Test Team 1583
Unread 06-02-2007, 09:40
Re: pic: Ramp Drop Test Team 1583
the video can be seen at http://www.youtube.com/watch?v=yt0u_vh3KM0
Unread 06-02-2007, 10:29
Wedge34's Avatar
Wedge34 Wedge34 is offline
FRC #0868 (TechHOUNDS)
Team Role: Student
Wedge34 is an unknown quantity at this point
2 bots? or 1? Only function?
Unread 06-02-2007, 10:31
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
way to get it done. Time to practice! I'm taking a certain interest in this robot because of its simplicity. Quick question, why arent there any treads on those wheels? you might want to consider that.....
Unread 06-02-2007, 11:17
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Deployed the level surface 12 inches high is 37 x 76 inches which is more than enough room for two bots with bumpers. Remember the wheelbase of the bots is what counts. That's another way of saying the bot chassis can overhang the ramps. The video was shot without the center ramp sections in place. They're ABS panels that are attached with screws. We're going to a scrimage a week from this weekend where we'll invite everybody to try "driving up". Following the scrimage we may enhance traction on the ramps if needed. Some of the ideas of "how 2" do that are sandblasting the tread area of the diamond plate and cutting shallow cross hatch saw cuts in the ABS. Our idea from the start has been to pick a simple strategy and become really good at it thru design and practice. The simple design has enable us to have an almost finished bot that our drivers are already driving around. A good driver can make a so-so bot look great while a so-so driver can make a great bot look bad. Even though we're in the 100 LB 72 inch tall category we're under weight. Life is GOOD
Unread 06-02-2007, 11:38
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Very nice looking robot. One question: have you thought about putting side rails on the ramp to prevent robots from being able to drive off your robot accidently?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 06-02-2007, 11:51
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
There are side rails on the second ramp which is the last one you'll drive on. We considered them for the big ramp but nixed the idea. If you can't drive up a 38 inch wide ramp to start with rails are not going to help much. Effective rails would have to be more than 3 inches tall.
Unread 06-02-2007, 18:44
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Good job executing the design!
Alas, that comment on youtube, "what the heck does it do" will probably be a very very common view from the public. (though you did say you'll have an arm... so you'll escape that some)
Unread 06-02-2007, 21:24
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Is it dangerous? Does it have something to slow the impact of ramp-to-floor. Other than that Great design
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 07-02-2007, 01:08
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Yes, we have flat aluminum pads on the ramp feet that have 1/2 inch thick dense foam pads attached with zip ties. Works well. In fact this evening we deployed the ramps on carpet for the first time. We snuck into the school library (only big carpeted area we could find) and let them go. We've now dropped them more than they would be dropped at any competition with no problems or anything to change.
Unread 08-02-2007, 23:23
coolguybigt's Avatar
coolguybigt coolguybigt is offline
engineer rock (software is fun)
AKA: T
FRC #2043 (Robo Squad)
coolguybigt will become famous soon enoughcoolguybigt will become famous soon enough
Send a message via AIM to coolguybigt Send a message via MSN to coolguybigt
how much do your robot weight
do your robot do any thing esle to score point
Unread 09-02-2007, 00:30
windup zeppelin's Avatar
windup zeppelin windup zeppelin is offline
AKA: Gavriel
FRC #1515 (MorTorq)
windup zeppelin has a spectacular aura aboutwindup zeppelin has a spectacular aura aboutwindup zeppelin has a spectacular aura about
Oh wow, one of our members came up with the same design about a week into the building season. I'm just wondering, isn't it a little risky to be a ramp bot only since you have to rely on your alliance to score during the match.
"I wanna hang a map of the world in my house. Then I'm gonna put pins into all the locations that I've traveled to. But first, I'm gonna have to travel to the top two corners of the map so it won't fall down."
2007 LA Website Award
2007 LA Autodesk Visualization Award
2007 LA Imagery
2006 NV KPC&B Entrepreneurship
2006 CA Autodesk Visualization Award
2006 CA KPC&B Entrepreneurship
Unread 09-02-2007, 02:42
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi John & Gavriel, First the bot currently weighs a little less than 100 LBS. You can bet that by 'turn in' it will weigh very close to 100 . Yes it is risky to be dependent on your alliance partners to score but we think it's worth it. Playing defense and keeping the opposition from scoring points is as valuable as scoring ponts yourself.
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
pic: Team 668 Robot Ramp 1 burkechrs1 Extra Discussion 0 05-02-2007 23:40
pic: 1583 Rambotics rampbot WRGibbens Extra Discussion 9 30-01-2007 23:23
pic: Team 1712 First Test IraJason Robot Showcase 3 15-02-2006 14:18
Extra ramp and platform outside the field at each event to test and practice? Digo General Forum 4 19-01-2003 21:39
