Go to Post The on-going debate on this thread is just because we care. - Steve Wherry [more]
Unread 06-02-2007, 21:04
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Digital to Analog Converters
I know some teams have successfully used them to interface to the OI before.
Can some one give provide me with some recommendations for some simple to program, cheap D/A converters?
This is going to be used to interface a custom circuit to the OI.
Thanks
Unread 06-02-2007, 22:15
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Digital to Analog Converters
You might want to look at how team 862 interfaced a playstation controller. Their whitepaper says what components they used.
You could also look at Microchip's digital pots.
I don't have any experience with the microchip parts, but I think they should work.
Eric Haskins KC9JVH
Unread 07-02-2007, 00:25
Jared Russell's Avatar
Taking a year (mostly) off
There are a variety of DACs that you can build using discrete ICs, or even just resistors. Google things like "R-2R" or "Weighted Resistor DAC".
All the same, I do suggest that you look into digital pots if they fit your application...it will save you some time.
Unread 07-02-2007, 00:48
AD looks like a good place to start.
http://www.analog.com/en/cat/0,2878,761,00.html
Unread 07-02-2007, 01:18
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Drop me a PM if you'd like. we just implemented a I2c->Analog sensor interface using the AD8652. It's a really easy to use R-2R dac which outputs the binary value from 1mv -> 4095 mV in 12 bits.
Also, if you have PIC programming capability, you could use a I2C / SPI dac and get better performance... not that it matters with the 8 bit OI ADC.
Unread 07-02-2007, 09:34
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
It depends on how much resolution you need, but the easiest way to do an 8-bit D/A is to use a PWM channel and an RC filter. Just be sure the time constant of the filter is much larger than the period of the PWM signal. You can do a search on the internet to find examples of a PWM/RC D/A.
Unread 07-02-2007, 22:52
6600gt's Avatar
AKA: Lohit
Thanks everyone.
I really don't have the time to develop much hardware(soldering up a whole string of registers). I want to use this system this year, and the deadline is approaching fast...
I do have access to PICs with SPI or I2C interface, in fact, that is what I intend to use. I would like to have a 4 channel output to be able to take advantage of one full port(able to send 4 bytes at a time)
I am looking at D/A converters because I need the full range. Its going to be used for data communications(analog port is the only legal way to get to the RC from the OI). Some one on one of the other threads said that digital pots have a +/- 30% resistance variability so...
I was looking at some Maxim DACs, and they seem like they would get the job done. Any specific suggestions on what types or features I should be looking for? I just need something that I can get going with fast!
Thanks
Unread 08-02-2007, 00:16
If you are indeed doing this on the OI, keep in mind that you are limited to a MAXIMUM of 100mA from the 4 joystick ports combined, and these are the only legal power sources for your OI components (the Chicklet is the exception to this rule).
That's going to mean that whatever you design has to be very low power.
Unread 08-02-2007, 00:49
6600gt's Avatar
AKA: Lohit
I thought it was 100mA per port! How much power does each individual joystick pull?
I am going to put an LCD on there without back lighting so it should only pull about 30mA and the PIC and MAX232 should pull about 20mA so I think it will work.
It will be sweet if it works though...
Unread 08-02-2007, 11:49
Why not just use one of Analog's serial input quad DACs and bitbang the outputs? you could probably get a quad dac working faster that way than writing your own I2C stuff (unless you're already odne this, in which case its a moot point..)
Unread 08-02-2007, 22:11
6600gt's Avatar
AKA: Lohit
Do you think this will get the job done? Are there any special characteristics that I should be looking for?
Unread 08-02-2007, 23:27
that looks good. SPI is a plus, as PICs have SPI support built in (usually).. 8 bit quads are good since the OI is 8 bit (last I remember anyway) what you picked seems ideal to me. PM me if you have any problems.
Digital to OI Analog marcan Control System 33 05-02-2007 12:46
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
