Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
Unread 08-02-2007, 10:32
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
Help! Radio not working
Our 2007 Robot Controller radio stays in standby mode. The operator interface radio has transmitt led lit. We tried the 2006 radios same thing. We tried 2007 radios on 2006 controllers, OK. Is our 2007 RC bad? everything elseworks ok.
Unread 08-02-2007, 11:06
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: Help! Radio not working
Did you set your team number dip switches and teather the RC and OI before attempting to use the radios?
--Dave
Unread 08-02-2007, 11:24
My standard advice for this symptom is to make sure you've tethered the OI and RC with the red cable to get the team number set properly in the RC. Then make sure you know the black radio cables are good. After that, call IFI and tell them what's happening. They'll be able to guide you through troubleshooting the system, and if it's still broken after all that, they'll be able to arrange a replacement radio.
Unread 08-02-2007, 13:02
FRC #1277
Ya know, in our rush, I don't think we set the team number on the 2007 controller. Will try that tonigt. TNX!
Unread 08-02-2007, 22:32
FRC #1277
Everythings working ok. Didnt do anything different, tho. maybe the moon was in a bad position. Thanks to you guys.
Unread 08-02-2007, 23:09
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
It sounds really dumb but it took us a while to figure out...so make sure you have to CORRECT radio on the robot and OI...they ARE labeled. It's amazing how you can over look something so dumb (it was our programmers fault who hooked them up!!)
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 08-02-2007, 23:44
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Right now our radios are not working at all. . . We tried to trouble shoot them best we can. . . Works fine with the tether, but once we disconnect it and hook up the radios we get nothing. . . . Both radios just flash standby. .
Tried re downloading the master code and user code and nothing. . .
Going to call IFI tomorrow but can't get to the robot during regular business hours. . . Would I be better off just to e-mail them the situation??
[edit]We did try different cables on the radios[/edit]
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 12-02-2007, 17:21
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
We're in a similar situation. Our radio control seems to come in and out. Our biggest problem right now is a safety issue - the robot at some points stops getting data from the OI (I suppose) and just executes its previous command.
Now, I'll admit that I am not an expert at designing microprocessors, but how is this safe? We need our disable dongle to work to prevent damage to people, property, and robots. IFI talked about this issue in Updates 6 and 8, but as far as we could tell, their beta code didn't help one bit.
Also, if the beta version was released a week and a half ago, why hasn't there been a follow-up? If it works as intended for most teams (i.e. we're an anomaly), why hasn't it been declared a final version? If it doesn't work, why haven't they come out with a new version or at the very least acknowledged the problem?
I'm really puzzled by this. Does anyone have ideas/suggestions on how to fix this problem? We've tried normal and 14 beta master code, default code, the dongle, and switching cables. Any ideas?
Thanks,
Paul
Unread 16-02-2007, 08:13
Bruno Inácio's Avatar
Bruno Inácio Bruno Inácio is offline
Bruno Inácio is an unknown quantity at this point
Ours radios are with same problem......Who knows how to correct them...?
Thank's
Unread 16-02-2007, 09:06
legotech25's Avatar
legotech25 legotech25 is offline
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
legotech25 will become famous soon enoughlegotech25 will become famous soon enough
Send a message via AIM to legotech25 Send a message via Yahoo to legotech25
A lot of people are having radio problems. Ours cuts in and out frequently, and some of the other teams that I talked to were having the same problem. We're going to switch over and use last year's transmitter/reciever for practice, but I don't know whats going to happen if this keeps up at the tournaments...
Team Captain - More Robotics 1714
2009 Milwaukee - Chairman's Award
2008 Milwaukee - Chariman's Award
2007 Cleveland - Kliener Perkens Buyers Caufield Entrepenureship, Engineering Insparation
2007 Milwaukee - Kliener Perkens Buyers Caufield Entrepeneurship, Website, Motorola Quality Underwriters Laboratory Safety
2006 Atlanta - Rookie Inspiration
2006 Cleveland - Rookie All-Star, Safety Runner-up
2006 Milwaukee - Rookie All-Star, Safety Runner-up
pi = 3.141592653589793238462643383279502884197169399715 10 ^_^
Unread 16-02-2007, 11:55
Have you called IFI and raised your concerns?
Unread 16-02-2007, 13:40
Ultima Ultima is offline
FRC #0369
Ultima will become famous soon enough
For the past couple of days since we started to practice with our chassis we have noticed a very weird thing. Sometimes the robot seems to lose control, especially during the times at which victors supply a large amount of current to the motors. One time the robot accelerated by user input however when the joysticks were released the robot continued to proceed for the set of lockers at about 15 feet per second, once the robot hit the wall control was regained however our freaking frame was bent and the lockers suffered a terrible fate as well. After that incident there were 2 more not as dangerous but still leaving us with doubts about controlling the robot in the presence of people.
IFI - Please clarify on this issue.
Unread 16-02-2007, 14:21
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I wonder if the new radios are more susceptable to multi-path interference, such as might be caused by a row of metal lockers across from the control station.
Why IFI abandoned the reliable radios from previous years is beyond me!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 16-02-2007, 20:00
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
IFI's former radio vendor was unable to obtain parts to build more, so they had to come up with an alternative solution.
After receiving our radios back from IFI a few weeks ago, we saw an improvement, but still see quite a few communication dropouts. IFI has yet to offer us a solution so we have now turned to FIRST for help.
I see packet loss occurring at varying distances (5' to 50') and overall range appears to be good (150'-200') and for the most part seems to be coupled to demands on the electrical system, though Wednesday night we witnessed an event when the motors were not running. Neither a freshly charged, nor almost depleted battery seems to make any difference.
... and yes, radio problems have created some near misses with even my own toes.
Substituting old radios resolves the problem.
--Dave
PLEASE HELP: OI switch box not working RbtGal1351 Control System 2 18-02-2006 19:34
reverse of motors NOT working please help Stillen Control System 4 11-02-2006 22:05
my comp is not working right and i need help Timmyd Chit-Chat 17 07-11-2005 23:39
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
Radio problems -- not archiver 2000 1 23-06-2002 22:23
