Go to Post Design is iterative, right? - JesseK [more]
Unread 08-02-2007, 23:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Autonomous Mode
Originally Posted by dpick1055 View Post
Could someone please explain how to "switch" into autonomous mode without using a dongle. I want to test my autonomous code but haven't had time to make a dongle yet. Thanks
You really should use a dongle. They're easy to make, and you can't forget to change anything back before you go to a match. (I'd hate to be plugged into the field and the IFI guy coming up and saying, "You're team number isn't set.")
If everyone on your team is deathly afraid of soldering, you can buy a dongle from AndyMark.
Autonomous Mode Slick Programming 22 01-02-2007 19:26
autonomous mode seanl Programming 6 31-01-2007 15:59
Autonomous mode chs938 Programming 1 03-02-2006 10:19
Autonomous Mode David Bryan Programming 1 21-01-2003 21:15
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
