Re: Disable Encoders Problem
I would still recommend that he comment out the #defines in the header file. Doing so would both disable irrelevant interrupts, and eliminate code that won't be called anyway from the hex file. |
When he said he wanted to disable an inactive encoder, I took it to mean the encoder was to be active for a while, possibly during autonomous, and then be disabled, not that the encoder was totally absent.
good luck, and if I can help, gimme a yell. -Q |
I've never understood the && with the enable bit in the interrupt handler. If the interrupt isn't enabled, there will be no jump to the interrupt vector so that test will never be executed. Without the interrupt enabled, it's just an ordinary input pin.
-Kevin |
#7
There is only one (low-priority) interrupt handler. It will be called when any interrupt occurs, and the handler has to check all the possible sources in order to service the interrupt properly. The program won't know not to deal with a flag for a disabled interrupt unless you also check the associated enable bit. You don't really want a serial port interrupt to end up running the service routine for a "disabled" encoder.
#8
Thanks for all the help.
#9
This is where I part company with MicroChip's implementation. If you don't enable the interrupt, it should never set the interrupt flag for that interrupt, in my opinion, because an interrupt should not have occurred. I guess one more reason I'll probably opt for something other than PICs for my personal projects. |
| Autonomous enable/disable | Culvan Van Li | VEX | 4 | 21-09-2006 13:03 |
| Bypass Disable Switch | jakep | Control System | 36 | 19-08-2006 12:46 |
| Question about human disable | Collmandoman | Programming | 6 | 10-03-2005 23:30 |
