Go to Post I'm looking foward to the challenge! - Adrienne E. [more]
Unread 08-02-2007, 23:47
Jared Russell's Avatar
Taking a year (mostly) off
Re: who's going to use eprom
EEPROM is perfect for control loop constants. You can hook up a controller to the OI to update a constant (say with a joystick wheel), and then press a button to "save" the data.
Functionally, you can think of EEPROM as a "hard drive" for your robot. Whatever you put in there stays even after you power off. But, like a hard drive, you are limited in space (though honestly there's plenty for most uses), and reading and writing is a bit slower than to working memory.
Unread 09-02-2007, 00:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Originally Posted by Donut View Post
For those of you using EEPROM; what's the advantage in storing values in there rather than in ROM data?
EDIT:Ignore this, and read page 15 of the MCC18 user's guide instead. (Foot, meet mouth...)
IIRC, when you declare a variable as "rom", it is still stored in EEPROM, but the location is allocated by the linker. When you use Kevin's library, you choose the location itself. Data is never stored in the program memory (flash). Also, "rom" variables are reset to default values when the program is downloaded.
Meaning you probably shouldn't be mixing the "rom" keyword and Kevin's code.
If you're really interested in the details, experiment. Look at the list file after playing with a rom variable. And yes, you can store to a rom variable.
Last edited by Astronouth7303 : 09-02-2007 at 00:54. Reason: Open mouth, insert foot.
Unread 09-02-2007, 00:26
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
This is not correct; the rom qualifier specifies that the variable be referenced in program (i.e. flash) memory, while the ram qualifier forces it into static RAM (where the near and far qualifiers also apply, but that's for using GSRs and SPRs in special ways, which not many people here would need). You should use the rom qualifier if you're storing large arrays (i.e. lookup tables) in program memory. The qualifier is necessary so the compiler can generate the necessary table reads and writes to flash. EEPROM reads and write are done independently through the EECON, etc registers.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Who's going to Waterloo? Francis-134 Regional Competitions 13 23-03-2005 09:25
Who's Going to Drexel?!?!?! fred Regional Competitions 23 30-03-2004 17:35
Who's going where? meaubry General Forum 6 02-11-2002 15:22
Kickoff--who's going?? archiver 2001 18 23-06-2002 22:08
Who's going to Philly? archiver 1999 6 23-06-2002 22:00
