Go to Post I'm gonna laugh when the GDC numbers the first official game hint #3. - Racer26 [more]
Unread 08-02-2007, 13:13
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Planetary trouble
Does anybody else have trouble with the planetary gears, and if you figured it out help us out, our gears broke or something.
Unread 08-02-2007, 13:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Planetary trouble
There has been a lot of discussion about this recently, see some of these threads
http://www.chiefdelphi.com/forums/se...earchid=652755
The big black/chrome planetary gearboxes are the 56mm type, the smaller one is the 36mm type.
Unread 08-02-2007, 23:33
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Try taking apart the troubled gearbox and take a look around. They come apart quite easily, and believe it or not, are quite simple.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-02-2007, 00:26
windup zeppelin's Avatar
windup zeppelin windup zeppelin is offline
AKA: Gavriel
FRC #1515 (MorTorq)
windup zeppelin has a spectacular aura aboutwindup zeppelin has a spectacular aura aboutwindup zeppelin has a spectacular aura about
oh man, we had the same problem. Our fault was that there was a small disc that stops the gears from moving up and down or else the gears get chewed, and we forgot to put the disc in .
"I wanna hang a map of the world in my house. Then I'm gonna put pins into all the locations that I've traveled to. But first, I'm gonna have to travel to the top two corners of the map so it won't fall down."
2007 LA Website Award
2007 LA Autodesk Visualization Award
2007 LA Imagery
2006 NV KPC&B Entrepreneurship
2006 CA Autodesk Visualization Award
2006 CA KPC&B Entrepreneurship
Planetary Gearbox Possibility? ThatIndianKid89 Technical Discussion 4 04-02-2007 17:18
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Designing a Planetary Wheel (Almost) lndnny General Forum 14 25-10-2005 15:27
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
