Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
View Poll Results: What do you think?
MPLAB is the only thing I have installed 49 65.33%
Rarely use MPLAB 6 8.00%
I use both about the same 2 2.67%
easyC is the only thing I have installed 18 24.00%
Voters: 75. You may not vote on this poll
Unread 09-02-2007, 00:56
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: What is Easy C good for?
Originally Posted by Astronouth7303 View Post
I have to weigh in on the con side, here.
I have, in fact, used EasyC. I can see its usefulness at a high level. But as you start drilling down, it becomes more cumbersome.
Examples:
Math - Everything has to be in temporary variables or you inline C code.
Preprocessing - I didn't look much into this, but I'm not sure about EasyC's preprocessor support. I use it extensively, and, frankly, I'm not sure I could do in EasyC what I do in text editors (again, inline C doesn't count).
Inline Assembly - I have, in fact, briefly considered this for real robot code from time to time. I somehow doubt that EasyC supports it.
Now, comparing EasyC to MPLAB is not really a fair assessment. MPLAB is some of the worst software I have had to the misfortune of working with (along with MCC18, CoreChart, and IFI Loader). Comparing EasyC to, say, a well-equipped copy of Eclipse (or some of the other IDE). I doubt EasyC could handle Subversion, compiling for multiple controllers, concurrently open projects, or the search capabilities (Where is this thing declared and defined? Where do I reference it?). That's not even getting into the multiple languages Eclipse can support (I have used python in my FIRST code, and for the Makefile).
The only way I saw myself using EasyC was to write the high-level code and writing the actual hardware "drivers" in a separate library in C.
Of course, this is also with 3 years of code behind me. I don't have a "library", per se, but I do have a set of macros, functions, etc. that I reuse, plus a "standard" code layout. I mean, how many different ways can you implement a PID loop?
As for the "EasyC challenge", there's a difference between "can do in EasyC", "can do easily in EasyC", and "have to use inline C code to do it". eg, You can do some sick stuff in the preprocessor:
#define LINE(txt) #txt "\r\n"
#define PID_VARS(prefix) int prefix##_pid_p, prefix##_pid_d; static int prefix##_pid_i
#define MSG(fmt) #__FILE__ ":" #__LINE__ ": " #fmt "\r\n"
I have considered using all of these in FIRST code (except the last one, but I really should). (OT: Does MCC18 support variadic macros?)
Please correct me if I'm wrong, here.
My $.02
Great points.
And yes, I believe MCC18 should support them, as it uses the GNU cpp (look for the source code, it comes with every install ).
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Hardware is all good, what do i do now for software? GraphicArtDesig Programming 9 20-01-2006 21:50
What time would be good for a SW Florida offseason? Adam Richards Off-Season Events 0 17-01-2006 01:44
What do you think about how easy theyre making programming? Leav Programming 76 11-01-2005 12:07
Looking for an easy website for your team? Jack Website Design/Showcase 2 30-12-2003 23:32
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
