Go to Post My students want me to confirm if they're only allowed one submission per team? (Apparently they've gotten a sudden wave on linguistic inspiration...) - Siri [more]
Unread 09-02-2007, 11:02
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Mecanum Wheels
Hello,
In the off season, or before the Las Vegas regional, we would like to explore the idea of mecanum wheels. What is the best way to drive these wheels? We were thinking of using the BaneBots 56mm Planetary Gearbox with the CIM motor. The BaneBots shaft would go directly into an Andy Mark 1/2" universal hub which would be attached to a wheel. Would this be a good idea or should we go with a chain driven design, we have had bad experience with chains.
Unread 09-02-2007, 11:08
underwood's Avatar
underwood underwood is offline
lead machinist
AKA: alex
FRC #1072 (Harker Robotics)
underwood is an unknown quantity at this point
Re: Mecanum Wheels
we are using mecanums this year. we found that it is soooooooo much easier to mount directly and just avoid chain alltogether. good luck!
My Famous Last Words Will Be:
"I dunno, press the button and find out."
If life gives you lemons, find someone who's life has given them vodka and have a party.
"Bad artists copy. Great artists steal."
-Pablo Picasso
"Anyone who has never made a mistake has never tried anything new"
-Albert Einstein
MECHANICAL MONKEYS RULE!!!
Unread 09-02-2007, 12:46
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
Re: Mecanum Wheels
We learned that you need two universal hub on each or you get this weird wobbling action. I guess your using AM mecanum wheels, right?
Unread 09-02-2007, 12:55
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
Re: Mecanum Wheels
http://www.chiefdelphi.com/media/photos/26582?
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 09-02-2007, 13:02
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Mecanum Wheels
Be sure to support both sides of the shaft. cantilevering the banebots may not be the best idea...
Suspensions are also useful. do a CD search on that too.
drop me a PM if you have any questions.
Unread 09-02-2007, 13:04
AKA: Calvin
Re: Mecanum Wheels
Thanks
Yes, we were thinking of using the Andy Mark mecanum wheels.
And by the looks of your picture there, team 384, you used a custom gearbox. Would it be more efficient to make our own, I know it would be a space saver. On a side note, where did you get your material for your frame? It is so awesome, hope you make it all the way! Great design.
Unread 09-02-2007, 13:13
dtengineering's Avatar
AKA: Jason Brett
Re: Mecanum Wheels
We are using the AM Mecanums direct mounted to 12:1 Banebots 56mm trannies. They work great... we probably have an hour or more of driving in now, and while the backlash in the trannies is getting greater and greater, they are still working. The 12:1 ratio results in a fairly fast robot, but if you're building an omni-drive that is what you want... to out run, not out push your opponents. We are going to keep our eye on this however, as right now we have only run the robot at about 50% of the final weight. As we add mass we may want to increase torque a bit... as it is we spin the wheels before we stall right now, which means we have more torque than the wheels can handle.
We have found that using encoders and closed-loop speed control greatly improves your handling... while I hesitate to call it a necessity, you probably really, really want to think about adding encoders. I believe the gyro may also help with directional control.
The banebots encoders and divider cards work great too, however there is one complication that can ensue... the BB trannies can develop sufficient end play that as the shaft slides in and out of the gearbox the encoder disc rubs up against the encoder optics and shreds the sensors. At least that was our analysis of the problem. To solve this, if you notice too much end play in your gearbox you can pull the gearbox apart (Banebots users should be pretty good at this by now...) and pull out the inside bearing on the shaft mount, and machine a spacer to keep the inside and outside bearings sufficiently far apart that there is no room for end play because the shaft shoulder and circlip are both tight against bearing surfaces.
You will also want to be VERY sure that you support the BB trannies at both ends, rather than cantilevering the wheel off the tranny alone.
Many threads will say that mecanums require a suspension system. We have a rolling drive train that demonstrates that a suspension is not required... however we have intenionally left a great deal of "flex" in our kitbot frame and paid attention to trying to make an equal distribution of weight to each wheel. The mecanums, as you might suspect are more sensitive in this regard than a traditional 4wd or 6wd drive train.
If you are looking for more info on mecanums, try also searching for common mis-spellings such as "mechanum" and "meccanum". There is good info in the CD white papers section.
The BB trannies are an acceptable option for direct drive of mecanum wheels, and should BB get on top of manufacturing tolerances and quality control they will be a great option.... although in some ways having a "rough and ready" gearbox that needs tweaking does provide a good learning experience on how planetarys work.
See you going sideways.
Jason
Unread 09-02-2007, 13:29
AKA: Calvin
Re: Mecanum Wheels
awesome, thank you to everyone who has posted, your advice has helped a great deal.
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
COTS Mecanum Wheels kmcclary Technical Discussion 1 10-01-2006 17:17
Improved Mecanum Wheels techtiger1 Technical Discussion 23 08-10-2005 01:02
