Go to Post This should go without saying, but for some reason it always needs saying. - GaryVoshol [more]
Unread 09-02-2007, 01:10
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Help with cmu2gui
I'm now running kevin's bells and whistles code and its working fairly well. His camera menu works just find and the camera will find the lights. However I am trying to use the gui from his website so I can see what the camera is seeing (I couldn't get labview to work right). I know I am making a connection to the camera because I am getting data in the terminal but when i run the gui it flashes the black screen and then closes. Does anyone know why this is happening?
On another note I also can't get the camera to lock onto the lights. It will find them and report back all the angles and information and then keep searching. I have tried adjusting the search delay but that doesn't seem to have any effect. Thanks for any help in advance.
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 09-02-2007, 01:31
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Help with cmu2gui
If the green LED turns on when you shine the light, the camera is tracking fine. Just no moving servos.
As for your GUI problems, I couldn't tell you. I know the old one (from 2005) isn't real flexible.
Unread 09-02-2007, 06:12
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
Thanks, we are still trying to learn the camera, as we are a rookie team
Unread 09-02-2007, 10:59
dpick1055's Avatar
David Pick
I know that the camera is tracking and finding the lights it just isn't actually locking on to the light. Or maybe i'm just mistaken and the camera isn't supposed to lock on the light.
Unread 09-02-2007, 11:12
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Red face Re: Help with cmu2gui
If the camera doesn;t track the light, a couple things need to be checked if using the default code:
1) In tracking .h you may have to reverse the pan and tilt sign numbers. Ours had to be reversed. If it is a +1, make it a -1 and vice versa.
2) The camera may be mounted upside down.
3) The servo pan/tilt inputs may be connected to the wrong inputs. look in tracking.h for pwm assignments.
Hope this helps!
Jim
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 09-02-2007, 11:35
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
If you choose a serial port that isn't valid in the Java program, it will close immediately with no error message. Make sure you are choosing a COM port that exists. Check it under My Computer, Properties, the Hardware Tab, Device Manager, Ports.
If you have a USB-Serial adapter, and it's working, you should see your COM port device listed in Ports. If you have a real serial port, it should also be listed under there.
--Eric
Unread 09-02-2007, 17:10
AKA: Jamie Bliss
Are you saying that the camera can track blobs in its view just fine, and that the servos are not operating correctly? Or is the camera failing to track the color blob?
If it's an issue with the servos, what is happening instead?
Help with designs Packmon_driver Technical Discussion 2 02-02-2006 15:06
Help with Programming double_check Programming 11 19-08-2005 00:15
help with Interrupts thoughtful Programming 5 08-01-2004 16:07
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Help with reactor Funnyanimator 3D Animation and Competition 1 16-02-2003 14:22
