Go to Post This whole experience, the entirety of what FIRST represents and promotes, is about inspiring individuals to make something more of themselves and creating a better world; when you consider this, our individual victories seem meaningless. - Dillon Compton [more]
Unread 09-02-2007, 09:33
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Mounting Fisher Price Gearboxes
Anyone have any good sollutions for mounting the white plastic gearboxes that come in the KOP
I am wiery of just drilling into it.
Thanks,
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 09-02-2007, 10:53
REVving up for a new season
FRC #2848 (All-sparks)
Re: Mounting Fisher Price Gearboxes
before last year We would always file one side down to make a flat, then open the gearbox and install screws from the inside out.
If you are looking for an easier mounting solution maybe you should look at www.banebots.com their 36mm gearboxes will accept the FP motor.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-02-2007, 12:01
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
FP welds a bar onto a nonrotating shaft than runs through the output gear hole. This provides a shelf for the gearbox to rest on and prevents rotation.
In the past we have wanted the shaft to rotate so we rested the gearbox on a piece of aluminum angle, 2x2 x 1/4 thk, and transfered the hole from the gearbox. The hole will end up against the web of the angle. we then used clamp collars on both ends to prevent axial shift.
You will have to adapt this for your application.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 09-02-2007, 12:25
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
In the past we have mounted the FP gearboxes using the flat surface on the rear of the gearbox and then pass a bolt through the center hole. Last year we used the gearbox to run the o-ring drive on our ball launcher. In fact, we mounted the gearbox to a 2x4 wood stud and used a lag screw to hold the gearbox in place and then lagged the 2x4 stud to our frame. It made a hard mounting situation pretty easy actually.
Good Luck
Unread 09-02-2007, 12:34
Dick Linn's Avatar
no team (Synergy)
Years ago, when the drill motors/transmissions still came with the actual plastic drill casing, we used expanding polyurethane construction adhesive as a bedding compound to form a flat base on the curved case. We put waxed paper on a flat surface, rigidly held the case in the proper orientation, then squirted the glue in the gap at the base, followed by a couple of wedges of scrap wood. Once cured, we held the whole assembly down with large hose clamps. We used PL Premium, which is available at Lowes I think. They have many types, but this particular one will stick to a lot of different materials, including metal. It costs about $3.50 a tube.
http://www.stickwithpl.com/Products/...PLProductID=14
If you use this stuff, do not get any on your hands or clothing!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 09-02-2007, 14:06
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We made a custom aluminum plate that bolts up to the FP gearbox. Then we put a 90 degree bend onto the bottom part and mount it to the robot, to mount them vertically. I'll post pics later tonight.
Originally Posted by Greg Needel;57490
If you are looking for an easier mounting solution maybe you should look at [url
www.banebots.com[/url] their 36mm gearboxes will accept the FP motor.
The 36mm gearboxes aren't a good choice for the FP motors. They fit the 42mm gearboxes, however, Nanebots has sold out of all their high torque 256:1 gearboxes, and will not be getting them back in stock. This leaves only the 64:1 as the gearbox with the most torque, which might not be enough. The stock gearboxes are 124:1, which might be a better option for your team now anyway.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-02-2007, 15:45
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
We make an aluminum adapter with radial screws that mates to the moving plastic wheel with the slots. We then pin the adapter to what ever shaft we are using. On the other side of the gear box we have a roughly triangular plate that goes over the three screws that hold the gearbox together. We remove the screws and drill through the plastic and use these three holes to mount the gearbox to the frame or arm or what ever.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
Unread 09-02-2007, 16:29
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
this year we're using 5/8" pvc material attached straight to the gearbox with bolts going thorugh the holes you see on the gearbox that hold it together. (i'm recalling this discussion we had from memory just now) then, we used aluminum angle to mount the gearbox perpendicular to a surface. relatively simple. so that's how we did/are doing it.
Unread 09-02-2007, 16:34
If you take a triangular plate or something similar, as long as it has at least one straight side as long as that "shelf" on the opposite side and end from the motor, then put a properly placed hole through where the output shaft would go, you should be fine. We've done that for years without a problem. If we have a mast, though, we've just used that.
Mounting / Connecting The Fisher Price Motor Xufer Motors 21 31-01-2006 20:16
Fisher Price Gearboxes Heretic121 Motors 2 30-01-2006 21:38
Fisher Price Gearboxes Nathan Pell Motors 7 06-03-2004 11:29
Fisher Price Motor Mounting Ashley Weed Motors 1 16-02-2003 19:29
Fischer Price mounting screw ateene Motors 1 09-02-2003 21:00
