Go to Post I think this thread needs a reminder that there's no h in mecanum. ;) - Lil' Lavery [more]
Unread 09-02-2007, 13:51
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
Re: Norgen Relief Valve
The relief valve parts were loose when the bag was open so one of our students took the end of the valve off and apparently put it back together again. I later found a small brass disc on the floor and they said that they recognized it. Is there an exploded view of this valve anywhere? I am not sure we have all the parts or if they are all back where they belong.
Unread 09-02-2007, 14:04
Electrical Engineer
Rookie Year: 1995
I would contact FIRST and ask for a replacement.
Mike Betts
As easy as 355/113...
Unread 12-02-2007, 03:50
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
FRC #2090 (P.E.T.T.)
nsr is on a distinguished road
Send a message via AIM to nsr Send a message via MSN to nsr
hmm, well today when i worked on our pnuematics we encountered difficulties with the valve and had to take about 4 hours just to find leaks in the pnuematic system and put teflon on all of our brass plugs and everything else that seemed to be leaking.
i would check to see if any other part of the pnuematics system is leaking before you try to ask for a replacement or anything... make sure that it's the part that isn't working.
good luck
Unread 06-02-2008, 19:44
Redbull2486 Redbull2486 is offline
FRC #2012
Redbull2486 is an unknown quantity at this point
just a question do you have to mount the relief valve on a certain side of the compressor
Unread 07-02-2008, 22:32
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Until this morning I would have said no. However, the discussion and ruling in the GDC Q&A in this thread says yes.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
where do i place the norgen relief valve? Reaper40 Pneumatics 1 25-01-2007 18:25
Where do we get a relief valve? P1d40n3 Pneumatics 4 17-01-2007 10:04
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Relief... Joel J General Forum 0 31-05-2001 17:07
