Go to Post Woah, boulders fired. - FrisbeeFunTime [more]
Unread 08-02-2007, 21:16
jschinell jschinell is offline
John Schineller
FRC #0353 (POBOTs)
jschinell is an unknown quantity at this point
using cylinders as guides
We have cylinders that can not be used as actuators per this years rules, but we would like to use them as linear guides with no pneumatic tubing connected to them. Can we do that??:
POBOTs team 353
Unread 08-02-2007, 21:19
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: using cylinders as guides
i don't see why not as long as you can't power them. if the judges get upset cut a slot in the side and say its not a cylinder
Unread 08-02-2007, 21:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
This is definitely a question for the Q&A. Pardon me for going a little bit zen here, but when is a pneumatic not a pneumatic? If there's no air being pumped into it, is it still a pneumatic, or just a metal cylinder with a striking resemblance?
My best guess is that it will not be allowed. I remember there being a Q&A in a past year where someone asked if they could use an additional, otherwise illegal motor on their robot, but without powering it. The GDC ruled that it was still a motor, even without power. In any case, these issues are only somewhat related, and rules from past years are not necessarily applicable to this year's game, you should ask the GDC to be sure.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-02-2007, 22:08
Electrical Engineer
Rookie Year: 1995
POBOTs team 353
This is definitely a question for the FIRST Q&A and I strongly suggest that your team post it.
In my opinion, if there is no connection to the air ports and they are open so that no pressure can build up, the component would not be pneumatic and can be used.
Note that it must be COTS, you would have to account for the cost in your BOM and you must demonstrate to the inspector that it is safe.
JMHO.
Mike
Mike Betts
As easy as 355/113...
Unread 09-02-2007, 15:53
John Schineller
FRC #0353 (POBOTs)
Many thanks
we posted to FRC Q&A
Unread 09-02-2007, 21:35
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Definitely use the Q&A answer, but be very very careful how you POSE the question!
IF the cylinders are COTS coupon-equivalent and unmodified, and are not being used in a specifically excluded purpose (such as for additional air storage), then what's the concern? Per <R45> and <R105>, this year you're allowed to use as many as you wish! IMO there's no reason to request a ruling.
You weren't specific on the specs of the cylinders in question. IMHO, The only situation where a ruling should be requested is if you're using a cylinder whose bore-stroke combination is NOT on the ordering coupon. Then you have the "is it a cylinder or a mechanical part" question.
Is that the case here?
- Keith McClary
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 16-02-2007, 16:19
kmcclary's Avatar
Rookie Year: 1994
Many thanks
Was it ever answered? If so, what was the result (and your opinion of it)?
- Keith McClary
Excellent machining guides sanddrag Technical Discussion 9 20-09-2006 12:39
Spinning Cylinders Rick TYler Technical Discussion 5 04-02-2006 02:36
IFI Reference Guides MikeDubreuil Control System 1 10-01-2006 12:13
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
FIRST Guides archiver 2001 0 23-06-2002 22:10
