Go to Post I think we can all remember, no matter our age, that we are always responsible for our own actions and reactions. - JaneYoung [more]
Unread 04-02-2007, 14:21
Tz0m Tz0m is offline
FRC #0333
Tz0m is an unknown quantity at this point
Storing functions to variables
I am trying to set a variable, type double, to a function that calculates distance. This is the code I have.
dist = 80.0/tan(tilt_angR);
If I use a printf statement to calculate and display "dist," the value caclulates and prints properly. However, I need to set this value to a variable. Any help is appreciated.
Unread 04-02-2007, 14:45
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Storing functions to variables
If I read this correctly, you're trying to make a function that returns a distance.
double dist(double tilt_angR)
  return 80.0/tan(tilt_angR);
That code will do what I think you want to do.
Unread 04-02-2007, 15:14
FRC #0333
Thanks for the help, but I have another problem. The variable tilt_angR is set to another function, and I am having the same problem as before. Here is my code.
tilt_angD = ((((int)TILT_SERVO - 124) * 65)/124));
tilt_angR = ((tilt_angD *3.14159265)/180.0);
dist = (80.0/tan(tilt_angR));
Thanks for the help.
Unread 04-02-2007, 19:07
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Remember that in C, those aren't functions or equations. They are statements, executed once.
To assign a function to a variable would be something like:
(type omitted) myfunc = tan;
So you need to declare all three variables, like so:
int tilt_angD = ((((int)TILT_SERVO - 124) * 65)/124));
double tilt_angR = ((tilt_angD *3.14159265)/180.0);
double dist = (80.0/tan(tilt_angR));
Just watch out for integer math.
Just be careful about your floating-point expressions, the RC doesn't like them much.
Unread 09-02-2007, 16:06
FRC #0333
Thanks for the help, but nothing has worked so far. We still have the same problem.
Unread 09-02-2007, 22:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I think we're having difficulties divining what you're attempting. If you could post some larger chunks of your code, such as where you're calling these statements and an example of the code where the printfs are working. Don't be shy about cutting and pasting a vast majority of your user_routines.c or zipping up some of your source files and attaching them to a post.
Unread 10-02-2007, 14:07
FRC #0333
Ok, I have everything setup properly now, I think. The only thing I need to do is assign the variable 'TILT_SERVO' to the variable I pass into my function, 'tiltS'. I am not sure where to declare my variable and how or where to set its value to 'TILT_SERVO'. I have attached the three files I have edited for my code.
File Type: c calcs.c (788 Bytes, 27 views)
File Type: h calcs.h (421 Bytes, 26 views)
Unread 11-02-2007, 17:14
FRC #0701 (RoboVikes)
when you call the function simply put TILT_SERVO in the parameter
i.e :
double range
void someFunction ( blah blah)
    range = DistanceCalc(TILT_SERVO);
or:
printf("The Distance is: %lf inches\n", DistanceCalc(TILT_SERVO));
if you want to assign your variable the value TILT_SERVO
just declare it (outside of the main loop, towards the beginning of the file under the #defines)
like this: double tiltS;
then insidde your main loop put this code:
tiltS = TILT_SERVO;
this is probably redundant and un-necessary since you already have TILT_SERVO holding the value of the camera tilt
also you may want to be wary of this line
tiltD = ((tiltS - 124) * 65) / 124;
you should change it to this:
tiltD = ((tiltS - 124) * 65) / 124.0;
Just to clarify that you do not in any case want to do integer division
Team 701
Unread 18-02-2007, 11:36
FRC #0333
I do not want to do integer division, but I have to. The robot controller does not support floats or doubles. I have the function printing an int and dividing it by a number in order to get a proper answer in inches. If I use a float and type cast it to an int and divide by 100, the function prints a blank space.
Storing the balls Max Brin Technical Discussion 4 18-02-2006 20:34
Math.h and Functions and Variables amateurrobotguy Programming 1 26-02-2005 03:19
PDF of all functions/variables! mikesown Programming 1 01-02-2005 18:56
Storing Tetras on Robot MisterX General Forum 22 15-01-2005 19:26
SCORing vs. STORing Chris Fultz General Forum 3 15-01-2004 13:36
