Re: Banebot 56mm gearbox - double D - V3 - It's Show Time.
Okay, the test results are in from one of my test teams.
Special thanks are due to Alan Fallone and the rest of Team 1279. They put in a lot of work for us. Thank you thank you. The Test: 500 Hard Cycles: Full Forward, Allow the robot to get to full speed, Full Reverse, Allow the robot to get to full reverse speed, repeat. 115lbs robot 6WD Roughtop Conveyor wheel tread Test 1: 16:1 1-CIM Test 2: 12:1 2-CIM Note that Alan reports that with the 2 CIM set up, they only could go 100 cycles before needing to replace the batteries. This is not a low energy jog around the park. See the attached pictures, but given the severity of the test, I expected much worse. There needs to be more data gathered, but I am beginning to believe that this problem would not have been a significant factor for almost all teams using the Banebot 56mm transmission. Stay tuned. Joe J. Last edited by Joe Johnson : 09-02-2007 at 16:54. |
| Banebot 56mm gearbox - double D - RELOADED | Joe Johnson | Motors | 82 | 09-02-2007 14:07 |
| Banebot 56mm gearbox - double D related | Joe Johnson | Motors | 78 | 31-01-2007 23:55 |
| Banebot Gearbox | chris31 | Technical Discussion | 45 | 15-01-2007 17:56 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
| 56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? | VEN | Technical Discussion | 4 | 11-01-2007 14:45 |
