Go to Post We started FIRST to achieve a common goal and not only will we leave with more knowledge and wisdom, we will leave as friends and thats what really counts if you ask me. :cool: - Hick18 [more]
Unread 09-02-2007, 12:49
RDD RDD is offline
RDD is an unknown quantity at this point
CMUCam Questions
HI EVERYBODY !!!!
I AM WORKING WITH THE RC OF 2005.
WILL THE CAMERA WORK WITH IT???
and another question I have downloaded the Version 2.1 of the "bells and whistles" to the RC and in THE IFI LOADER THE "COM1 TERMINAL WINDOW (baud rate = 115200)"
is empty and nothing happened.
what is the problem ???
plz help me!!!
Unread 09-02-2007, 14:21
Re: I HAVE SOME QUESTIONS
Yes, the camera works fine with the 2005 Robot Controller.
If you're getting absolutely nothing in the terminal window after connecting to the program port of the RC, perhaps the program is not running. The master processor doesn't let the user processor start until communication has been established between the RC and the OI. Do you have them tethered or connected by the radio modems?
Unread 09-02-2007, 14:29
RDD RDD is offline
I haven't tethered or connected by the radio modems
Unread 09-02-2007, 14:33
RDD RDD is offline
IS IT POSSIBLE TO TRACK THE GREEN LIGHT WITHOUT USING THE OI???
Unread 09-02-2007, 14:39
Well, there's your problem. You must have the RC and OI connected and talking to each other in order for the program to run.
Unread 09-02-2007, 15:02
RDD RDD is offline
Unread 09-02-2007, 15:47
Set your team number to 0000. This will run autonomous mode ALL OF THE TIME. So, write your test code in the autonomous function.
By the way, the shift key is your friend. Please don't use all caps.
Unread 09-02-2007, 17:02
RDD RDD is offline
a question
HI EVERYBODY!
do I need to calibrate my camera if I am using the kevin's code??
Unread 11-02-2007, 14:35
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Red face Re: CMUCam Questions
RDD,
No, Kevin's code comes with pre-calibrated values to read the green light. If you cannot see the green light, you have another problem to solve, first.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
[FVC]: Some Questions. Jialat FIRST Tech Challenge 3 25-01-2007 12:05
Some Newbie Questions irishninja CD Forum Support 9 18-04-2006 18:15
I have questions! Do you have answers? c-squared_2006 Off-Season Events 2 07-04-2005 16:10
Some questions and answers... Joe Johnson Off-Season Events 0 26-10-2001 12:56
Some Questions.... Lake Orion OCCRA 1 25-09-2001 20:20
