Go to Post Students... be sure to drill air holes in the crate though. Maybe toss in some cheetos for the programmers. - Andrew Schreiber [more]
Unread 08-02-2007, 22:21
mftaberner mftaberner is offline
FRC #0585
mftaberner is an unknown quantity at this point
Exclamation Disable Encoders Problem
This is the first year our team has used the encoders and we have discovered you need to disable any inactive encoders. Kevin's readme in the encoder project sais that instructions to disable encoders are in the encoder.h file. After checking the latest code, no instructions were found.
Are the instructions in another file or can someone give help on disabling the encoders.
Unread 08-02-2007, 23:44
Jared Russell's Avatar
Taking a year (mostly) off
Re: Disable Encoders Problem
All you need to do is the following:
1. Open "encoder.h"
2. Find the lines that look like:
#define ENABLE_ENCODER_1
#define ENABLE_ENCODER_2
#define ENABLE_ENCODER_3
#define ENABLE_ENCODER_4
#define ENABLE_ENCODER_5
#define ENABLE_ENCODER_6
3. Comment out any line that corresponds to an encoder you aren't using. For example, if you are only using encoders 1 and 3, you should make the section look like the following:
//#define ENABLE_ENCODER_2
//#define ENABLE_ENCODER_4
//#define ENABLE_ENCODER_5
//#define ENABLE_ENCODER_6
4. Re-compile. Voila!
Unread 08-02-2007, 23:47
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Just disable the interrupts the encoder is attached to. The encoder will continue to generate the signal but the processor will ignore it and the interrupt routine will not be executed.
Unread 09-02-2007, 00:35
Tim,
I would still recommend that he comment out the #defines in the header file. Doing so would both disable irrelevant interrupts, and eliminate code that won't be called anyway from the hex file.
Unread 09-02-2007, 05:22
AKA: Tim Craig
Originally Posted by Abwehr View Post
Tim,
When he said he wanted to disable an inactive encoder, I took it to mean the encoder was to be active for a while, possibly during autonomous, and then be disabled, not that the encoder was totally absent.
Unread 09-02-2007, 07:28
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Remember.... watch out though. Make sure to && your interrupt flag with the interrupt enable bit. When interrupt enable is off there will be no jump to the interrupt vector, but the flag will still get set. Didnt know if your encoder code already had this or not.
good luck, and if I can help, gimme a yell.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 09-02-2007, 13:47
AKA: Tim Craig
I've never understood the && with the enable bit in the interrupt handler. If the interrupt isn't enabled, there will be no jump to the interrupt vector so that test will never be executed. Without the interrupt enabled, it's just an ordinary input pin.
Unread 09-02-2007, 14:28
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yes, it's weird but Qbranch/Alex is correct. The interrupt flag gets raised (set to one) even if the interrupt is disabled.
-Kevin
Kevin Watson
http://kevin.org
Unread 09-02-2007, 14:29
There is only one (low-priority) interrupt handler. It will be called when any interrupt occurs, and the handler has to check all the possible sources in order to service the interrupt properly. The program won't know not to deal with a flag for a disabled interrupt unless you also check the associated enable bit. You don't really want a serial port interrupt to end up running the service routine for a "disabled" encoder.
Unread 09-02-2007, 18:27
FRC #0585
Smile Thank you
Thanks for all the help.
Unread 09-02-2007, 23:26
AKA: Tim Craig
Yes, I understand this part. Not as nice as processors that have a separate vector for each interrupt but beggars can't be choosers, I guess.
This is where I part company with MicroChip's implementation. If you don't enable the interrupt, it should never set the interrupt flag for that interrupt, in my opinion, because an interrupt should not have occurred. I guess one more reason I'll probably opt for something other than PICs for my personal projects.
Autonomous enable/disable Culvan Van Li VEX 4 21-09-2006 13:03
Bypass Disable Switch jakep Control System 36 19-08-2006 12:46
Question about human disable Collmandoman Programming 6 10-03-2005 23:30
