Re: Am i just not seeing it?
yes i have checked for all missing braces and semicolons. still nothing.
Can you attach the file?
Check the file the was compiled just before it, or more likely the last file #include'd in the the file where the error appears. Look for missing }s. The compiler is weird that way, although possibly technically right, as the faulty syntax isn't until something unexpected happens, like when you try and start one function definition inside another one.
Another way to isolate invisible errors inside a file is to put known-good code before and after the line with the error, eg. Code:
int someFunction(void) {
int i;
int j;
i = j /4; //this line is for some reason producing an error
return i;
int i;
int j;
printf("hello");
printf("everyone");
return i;
Good luck, Robinson |
| pic: Just was not enough room | Rich Wong | Extra Discussion | 6 | 15-04-2005 18:58 |
| It's not just about the competition! | Franchesca | General Forum | 8 | 28-07-2004 13:31 |
| digital inputs not valid just after initialization? | WizardOfAz | Programming | 2 | 26-01-2004 13:21 |
| NO, I'm not just reviving a dead forum | Hubicki | Rules/Strategy | 6 | 14-07-2002 17:44 |
