Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 09-02-2007, 18:21
Xenosthebest Xenosthebest is offline
FRC #0701
Xenosthebest is an unknown quantity at this point
Am i just not seeing it?
Every time i compile this code for our ramp control, itll tell me that i have a syntax error, when nothing is wrong.
Here it is:
Problem is here!---> static
void do_manual_override( void )
if (left_ramp_up == CLOSED)
left_motor_pwm = motor_up;
else if (left_ramp_down == CLOSED)
left_motor_pwm = motor_down;
else left_motor_pwm = motor_off;
if (right_ramp_up == CLOSED)
right_motor_pwm = motor_up;
else if (right_ramp_down == CLOSED)
right_motor_pwm = motor_down;
else right_motor_pwm = motor_off;
Any feedback is appreciated!
Unread 09-02-2007, 18:36
ebowla's Avatar
ebowla ebowla is offline
The Overmind
FRC #2016
ebowla is on a distinguished road
Re: Am i just not seeing it?
did you try double clicking the error to see where it goes?
Progamming Master
Disclaimer: May not be actually as good as claimed, not reliable for advice, and shirks away any real work.
Unread 09-02-2007, 18:38
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
That function compiles fine for me. My guess is that the error is actually in the line/statement above your function definition. Are you missing a semicolon, closing brace, or closing parenthesis there?
For example, I tried this code
/*Various declarations to get the function to compile */
int x // <--- Missing semicolon
static void do_manual_override( void )
and got the following error
test.c:18: error: syntax error before "static"
Hope that helps.
FRC #0701
yes, i put a little arrow where it goes.
Unread 09-02-2007, 18:44
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I put you code into a default camera routine and it compiled and linked. I suspect the error you are seeing is just above the line where the syntax error is occurring. Look for a missing bracket or semi-colon.
Team MARS = 1.523 AU from the SUN!
Jim E.
FRC #0701
yes i have checked for all missing braces and semicolons. still nothing.
Unread 09-02-2007, 18:46
in between teams
AKA: Luke Van Oort
Can you attach the file?
Team 1219: 2009 - Mentor
Unread 09-02-2007, 20:28
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Check the file the was compiled just before it, or more likely the last file #include'd in the the file where the error appears. Look for missing }s. The compiler is weird that way, although possibly technically right, as the faulty syntax isn't until something unexpected happens, like when you try and start one function definition inside another one.
Another way to isolate invisible errors inside a file is to put known-good code before and after the line with the error, eg.
int someFunction(void) {
    int i;
    int j;
    i = j /4; //this line is for some reason producing an error
    return i;
So do this:
    int i;
    int j;
    printf("hello");
    printf("everyone");
    return i;
And see if the compiler still says its on the same line, or if it is now stopping on the upper or lower printf(). If so, then you know your error is on either side of the statement you were looking at, so check for the usual missing ; or }.
Good luck,
Robinson
pic: Just was not enough room Rich Wong Extra Discussion 6 15-04-2005 18:58
It's not just about the competition! Franchesca General Forum 8 28-07-2004 13:31
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
NO, I'm not just reviving a dead forum Hubicki Rules/Strategy 6 14-07-2002 17:44
