Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Unread 09-02-2007, 15:27
Craig1989 Craig1989 is offline
FRC #0539
Craig1989 is on a distinguished road
One Side Drives Faster than the Other.
It appears I have the classic one side drives faster than the other problem (right side is faster). I believe this problem is caused because the motors spin faster one way then the other (correct me if I'm wrong). We are using 2 small cims on each side. How is the best way to resolve this problem, put a limit in the program maybe?
Appreciate suggestions.
Thanks
Unread 09-02-2007, 15:50
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: One Side Drives Faster than the Other.
There are so many answers to your question that it would be much simpler to answer if you gave us a little more information.
1) Are you using a mixing function to drive from one joy stick?
2) Are you using two joy sticks to drive.
3) Are you using a different control system, if so, what?
4) Do you have some sort of velocity feedback, like, gear tooth sensors installed?
With out that info, I would only be able to guess that you have a trim pot on a joy stick out of position.
Unread 09-02-2007, 15:57
FRC #0539
We are using the two flight sticks, both are identical. We don't have any feedback atm, we may install that later.
Additionally we have tried replacing the slower of the two with a different stick, this does not change the problem.
Unread 09-02-2007, 16:00
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
The best way is a feedback loop.
I've found that the easiest way is a gyro-based feedback loop that corrects for undesired yaw. Almost as easy is a speed-based feedback loop with shaft encoders that keeps the robot's wheels moving the same speed.
Unread 09-02-2007, 16:18
AdamHeard's Avatar
Lead Mentor
How difficult is this.
How did you determine if the driver wanted a straight line or not? did you look at the difference between the two sticks?
Any feedback would be appreciated.
Unread 09-02-2007, 16:19
billbo911's Avatar
Now that sounds like classic motor BIAS issues. Of course, binding may also be contributing.
Adding velocity feedback or as kaszeta suggested, a gyro would give you a single input to sample. GTS on each side would be a little more complex, but would give you more accurate control. It's your choice, but it sounds like some sort of feedback is in your future.
Unread 09-02-2007, 16:46
dtengineering's Avatar
AKA: Jason Brett
While feedback loops are the best way to get perfectly even performance on both sides, if you are experiencing severe undesired turning on a CIM drive system I suspect the problem is mechanical, not electrical.
My understanding is that the CIMs are very symmetric motors and exhibit almost exactly equal performance in each direction. (unlike some other DC motors that are timed for higher performance in one direction)
Check your drive train... gearboxes (does one turn more easily than the other?), chains (differing chain tensions can cause extra drag on one side), sprocket alignment, and bearing alignment for your axles. When you power down and turn the wheels by hand can you feel a different "stiffness" from one side to the other? Is your battery mounted to one side, or do you have other weight distribution differences? That might make a difference, too.
If you have access to a clamp on ammeter (or other convenient means of measuring current), put your robot up on blocks and run both sides full-forward and full-reverse. Does one side draw significantly more curent than the other? If so, that is a sign of a mechanical friction-type problem more so than an electrical problem.
For three years now we have used open loop control with the small CIMs and while the robots have not travelled perfectly straight, they have been good enough to be competitive.... once we got the tensions equalized and the transmissions broken in. There is, however, a limit to how good you can go with this, and if you want perfection you are going to need some form of feedback.
Jason
Unread 09-02-2007, 17:10
kaszeta's Avatar
Typically we use a single joystick drive (y-axis commands speed, and x-axis commands the turning rate), but the difference between the two sticks should work as well.
I've posted sample PID code for the gyro in some other threads, just look at some of my recent posts. Nothing terribly difficult to implement, although it helps to have an understanding of how feedback loops work.
Unread 09-02-2007, 18:05
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
One way you can slightly correct this issue is by putting your robot up on blocks and calibrating your speed controllers, if that doesnt work, you can try to do a more simple P function to correct for the difference between the two motor outputs.
Cheers!
Unread 09-02-2007, 19:21
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
do you have all 4 motors facing the same way?
http://www.chiefdelphi.com/media/photos/26744?
you can see how the motors have a identical position. one of them has a extra chain and sprocket to reach the wheels.
this could solve your solution also.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 09-02-2007, 21:12
Andrew Blair's Avatar
FRC #0306 (CRT)
Although, as posted before, the CIM's exhibit very little bias as produced, small factors such as slight mounting shifts, small binds in the motor itself, and other minor variables will affect the performance of different motors slightly. If the issue is not as simple or noticeable as a bind in one side or the other, you may want to try a different motor pair.
As far as software compensation, as also stated before, try adding a constant in front of you problem motor's output to adjust.
I would not recommend calibrating the Victors however. If the problem is not a static one, you will run into problems during autonomous, and it can create other unforeseen, mysterious issues. I speak from experience here...
-Sir Francis Bacon
-Albert Einstein
Unread 09-02-2007, 23:17
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Today we tried doing uploading a single-stick control, just so I could try it out (I was curious as to how it would drive). We had the same exact problem, one side was going faster than the other. This is why we ruled out one-stick driving, it's very hard to get the joystick perfectly in the y-axis to have even power, however, this probably can be fixed with better programming. If the joystick travels slightly diagonal, then a certain amount of power is applied more to the left motor, less to the right, and vice versa.
Once we switched back to our original tank drive (two joysticks), the robot drives like a dream. I prefer driving this way as well - try using two-stick control and see how your robot handles.
Otherwise it's mechanical. Test the gearboxes and poke around to see if theres any issues. Make sure the wheels are aligned perfectly with the chain, and the drive sprockets are properly mounted to the output shaft of the gearbox. Also if your chains are really tight, try slacking them up a bit, so they can be a bit more flexible.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 09-02-2007, 23:45
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
try calibrating your speed controllers. This a lot of times can be the problem.
Unread 12-02-2007, 11:00
Craig,
All of the above suggestions are great but no one mentioned that wiring might be an issue. If you have desigened the robot with all of your electrical on one side and there is significant length of wire feeding the side that is slow, you may be experiencing current reduction in that motor set. If you are using #12 wire there could be a significant drop in the wire.
Unread 12-02-2007, 11:09
Brandon Holley's Avatar
On a side note....
We received our 2 kit small CIMs...We looked at them, saw they were CIMs and put them in the locked cabinet until we needed them.
We took them out to mount em up, and I gave each motor shaft a quick twist. The 1st one was perfect, teh 2nd one, was horribly bound up. About half of the rotation was flawless, the other half required a bit of effort to turn. We figured we'd put it in the drive train to see if it would work itself out, but it appears that it may be getting worse. Any comments to this??
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
[wiki]: how to save more than one prog. in the RC Edourdo FIRSTwiki 1 04-02-2007 17:29
The American War on Science (FIRST is on the other side) JoelP General Forum 18 09-06-2006 14:47
Turning; easier one way or the other? FizMan Technical Discussion 14 03-07-2004 14:03
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
