Go to Post actually, I don't work with mechanics, so I just barely learned what Lexan was a few days ago...long story... It's amazing the variety of things FIRST teaches us!!! - tribotec_ca88 [more]
Unread 08-02-2007, 18:08
anilizer@752 anilizer@752 is offline
FRC #0752
anilizer@752 is an unknown quantity at this point
Wiring problems
my teams electronics board is complete, but the wires that are conected to the spikes make a clicking sound and keep moving. It only happens when I plug the 20amp snap on box's to the panel. what could be the problem?
Unread 08-02-2007, 18:18
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Wiring problems
The "snap on Boxes" are your auto-reset breakers, and the clicking sound is them saving your electronics. Check the polarity of your battery connectors pronto, make sure you wired red to red, and black to black. Check for shorts EVERYwhere... Try to avoid turning your 'bot on until you've found the problem.
Unread 08-02-2007, 18:26
dtengineering's Avatar
AKA: Jason Brett
Re: Wiring problems
Your Spikes may be attached backwards... M+ and M- should go to the motors, not the battery.
I only suggest this because after re-building our circuit board we found that our spikes were all placed backwards (and connected backwards) on the new board.
Jason
Unread 08-02-2007, 21:14
Re: Wiring problems
The wires are moving as very high currents pass through them creating a magnetic field which repels or attracts other metal on your robot. Check your wiring as suggested above.
Unread 10-02-2007, 01:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Wiring problems
Goodness, the currents they must be seeing to make the wires move...
Unread 10-02-2007, 10:18
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Wiring problems
Yea... they should also check to make sure that they are using the correct amperage breakers and the right gauge of wire. Like the others, check your polarity on everything, and make sure you have the wires going into the right side of your spikes. It sounds like you have the power going into the M+ and M- on the spikes. Big BIG no no! Make sure you attach them to the 12V+ and the GND connectors on the other side. Of course, red goes to the 12V+ and the black goes to the GND.
Also, if you can't figure it out, upload a picture or PM me and send it straight to my email. Please make sure it is high enough quality to follow your wires around your board.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Wiring Rules sparkyone Motors 9 16-01-2006 13:53
wiring? SPARKY1688 Electrical 4 31-01-2005 17:44
wiring Michael Leicht Inventor 2 21-01-2005 15:49
wiring. archiver 2001 1 24-06-2002 00:07
