Where can we order the acme rod tri-mount plastic piece and rods?
any info on where to order?
Re: Where can we order the acme rod tri-mount plastic piece and rods?
You can presumably order the official part from Kerk Motion at http://www.kerkmotion.com/products/l...howtoorder.asp
I suspect the kit part is identical to a precision modified-acme threaded rod, size 1/2"-8, 4 Starts. In which case it can be had from McMaster Carr. But only in 6 foot lengths for $128. If you're interested in that, the part number I'm guessing is 6350K23. The matching nut is 6350K43. It might be easier just to get two of the nuts and use all McMaster stuff in that case. Alternatively, you could ask around for teams that aren't using their lead screws. I'm pretty sure we aren't. I know there's not too many hawaii teams, but one of them might still be able to help you. Then you just have to contact Kerk Motion for a price for your BOM. |
| Acme Threaded Rods and Studs | Arkorobotics | Technical Discussion | 6 | 01-02-2007 16:48 |
| Where can teams order jumpsuits? | Spindash54 | Team Organization | 4 | 28-01-2006 20:41 |
| Where can you order pneumatics? | Nitroxextreme | Pneumatics | 4 | 09-02-2005 14:26 |
| In need of plastic drill mount | jjdebner | General Forum | 4 | 19-02-2004 20:56 |
| Plastic Motor Mount? | indieFan | Motors | 3 | 15-01-2004 00:03 |
