Go to Post Too complicated for Wildstang? Start browsing CD-media...... - AdamHeard [more]
Unread 10-02-2007, 07:43
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Re: BaneBots 56mm Gearbox - Second Stage Sun Seizing
Originally Posted by Adama View Post
how would we get the siezed sun gear off?
On our's, there was about a 1/16" gap between the the sun and the the last stage planet carrier plate. There was not enough room to get any gear puller we had on it, but the one BaneBots sells might have fit. We clamped the output shaft in a vise, put a cressent wrench on the "D" of the sun gear, and worked it back and forth to loosen it a little. Then a second person pried up between the carrier plate and the sun gear with two screw drivers (but not so hard so as to bend the carrier plate) while the first continued to work the sun gear back and forth.
Unread 10-02-2007, 08:33
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
We had issues with the end of the output shaft grinding. Not thinking, I didnt get any pictures. After we opened it, cleaned the grease and shavings out, put new grease in we checked to make sure that the output shafts were perfectly level. They work fine now. Our guess is that originally we didnt have the output shaft level.
Unread 10-02-2007, 10:59
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
thanks
my father and i got impatient and within a half an hour of my posting we had a pen torch and a screwdriver. we heated up the gear and pryed with a screwdriver and it came off in about a minutes worth of work. Besides the sun gear being really freaking hot for 10 minutes there was no damage. we then deburred the shaft and inside of the gear and put it back on. the sun spins freely now and after putting everything back together it works fine and in general sounds smoother and less strained.
Unread 10-02-2007, 12:52
roach1051's Avatar
roach1051 roach1051 is offline
Go Boilers!
AKA: Jack Roach
FRC #1051 (Technical Terminators)
roach1051 is on a distinguished road
We had the same sieving problem with ours. I spoke to Banebots on the phone, and was told to cut the post off the shaft, it really wasn't necessary. We did that, and everything seems fine now. It originally siezed while running it on the bench, no load, after about 10 minutes. We ran it after modification for about 20 minutes without issues.
Banebot 56mm gearbox - double D - V3 - It's Show Time. Joe Johnson Motors 34 18-02-2007 19:00
Banebot 56mm gearbox - double D - RELOADED Joe Johnson Motors 82 09-02-2007 14:07
New Banebots 56mm transmissions for sale fsracer Motors 1 07-02-2007 22:58
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
