Re: Crate problems
I am not sure why you would want lower ground clearance. The 4x4 is not 4" and the crates are moved by fork lifts. Over the past nine years we have always used 4x4's and have never had a problem.
Ken |
Re: Crate problems
We were going to put 2X4's in the notches to support the bottom of the bot.
Chris |
Re: Crate problems
4x4, then a sheet of ply, then rails on top so the bot doesn't ship on it's wheels. |
Re: Crate problems
Since a 4x4 is really 3.25 inches I would make sure you have 3.25 inches of clearance at all points under the base of your crate except where the 4x4 touches floor. If you want to add a 2x4 to support robot under floor of crate and would also add a 2x4 to the 4x4. Take it from some one has driven a forklift for about 30 years. You want as much clearance under crate as possible.
Re: Crate problems
Since the forklift needs at least that space to get under the crate to lift it up, I wouldn't change anything. But, what you could do is put an extra piece of plywood in their, whether loose or on hinges, to act as a ramp for an easy way to get it out of the crate, if you are able to do that.
Remember, you will still have to lift your robot on and off of your cart so if your trying to avoid that, it's kind of hard to. Just trying to help out! XD |
| Labview problems and code problems | ajsetter | Programming | 25 | 18-01-2006 17:07 |
| Crate Question | Gamer930 | General Forum | 2 | 11-01-2003 12:30 |
| CRATE WEIGHT!!!!!!!! | archiver | 2001 | 1 | 24-06-2002 01:03 |
| Crate | RBrandy | General Forum | 1 | 06-02-2002 20:59 |
| Crate question | DanL | Technical Discussion | 1 | 02-02-2002 16:41 |
