Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 10-02-2007, 13:27
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
Pragma
So, I've seen the pre-processor command #pragma in several files and have heard people talking about it, but I haven't a clue what it does. Can anyone explain this to me? o_ô
xXx.S3nS31-h4nz0.xXx
Unread 10-02-2007, 16:58
Electrical Engineer
Rookie Year: 1995
Re: Pragma
Try reading this.
Is your question answered?
Mike Betts
As easy as 355/113...
Unread 11-02-2007, 02:16
Re: Pragma
#PRAGMA is a compiler directive. It is a way to pass information to the compiler that is not standard ANSI C. Because of that, there isn't any standard. One compiler may have a #PRAGMA command that doesn't work with any other compiler.
The post the Mike linked to is one example of a #PRAGMA for the C18 compiler. Another example is in this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=51550 Another example, for one project using Borland C, I used #PRAGMA pack to tell the compiler to byte align a particular structure, instead of word aligning it like default. If I were to try to move that code to another compiler, I would have to find out how to byte align structures with that compiler.
You can find a full listing of all the #PRAGMA directives that the C18 compiler supports in the MPLAB C18 C Compiler User's Manual here: http://kevin.org/frc/C18_users_guide.pdf
You can do a lot of neat things with #PRAGMA, but it's also one of the easiest ways to write non-portable code (not a big deal for our use, but it is in industry).
ADC #pragma cprogrammer Programming 1 26-10-2006 20:42
