Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 10-02-2007, 13:59
fallen751 fallen751 is offline
FRC #2052
fallen751 is an unknown quantity at this point
Autonomous Two wheel problem???
So here's the problem:
We have 4-wheel / 4-CIM setup, each CIM running an independent speed controller. Normal drive code functions properly with the sticks, but when jump the ports on the OI to activate autonomous mode to track the light, only the back two wheels spin at all. Pulling up the dashboard viewer shows that all four CIMs are getting PWM values, yet the front two refuse to spin....
Thanks for your help...
Unread 10-02-2007, 14:08
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
Re: Autonomous Two wheel problem???
If you look at the speed controllers during autonomous mode, do the lights for the inactive motors change the same as the active ones? If Dashboard shows that the PWM values are being sent, I'm inclined to think that it would be an electrical problem rather than programming.
xXx.S3nS31-h4nz0.xXx
Unread 10-02-2007, 16:54
Jared Russell's Avatar
Taking a year (mostly) off
Check your speed controller calibration.
Unread 11-02-2007, 14:35
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Which pwms are you using? If using PWMS 13-16, make sure you've got the call to Generate_Pwms() being called in autonomous (or use Kevin Watson's spiffy replacement PWM13 to 16 code), or they won't be generated.
Unread 11-02-2007, 23:07
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
We just use a PWM y-connector (the red/black/yellow included in KOP) to connect ONE PWM OUT channel to the pair of speed controllers for the left side motors, and a second PWM OUT channel the pair of controllers for the right side motors.
Of course the speed controller pairs should be identically calibrated ...
Autonomous problem railerobotics Programming 7 07-02-2006 08:36
One or Two Wheel Shooter Nitroxextreme Technical Discussion 6 14-01-2006 01:10
Problem using two transmitters jamesgecko FIRST Tech Challenge 9 12-05-2005 09:30
Autonomous Problem... JoeFryman Programming 2 19-02-2005 14:56
Autonomous problem. Code\\Pilot Programming 8 10-02-2004 19:40
