Go to Post Well I guess that's better than some teams idea of team bonding which would be taping a wayward freshman to the wall with duct tape. - Koko Ed [more]
Unread 10-02-2007, 14:24
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Unhappy Coder Error Light
Now that our encoders count, we have other problems. PWM's one and two have enabled encoders. Sometimes when i run those motors they suddenly stop responding and the code error light starts blinking on the OI . could this be caused by faulty encoders? Or is it an infinite interrupt loop? The code compiles fine, with not even a warning (Using MPLab). What could be causing the problem? Thanks in advance
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 10-02-2007, 15:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Coder Error Light
There are a number of possible causes for this. One possibility is that your encoders are generating too many interrupts per second, which is keeping the rest of the code from completing its task in a timely manner. Can you give us more information about what encoders you're using, where they're attached to your drivetrain, and when the problem occurs (only when you're driving fast, or sporadically)?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 10-02-2007, 15:36
paulcd2000's Avatar
AKA: Paul Dagnelie
the generate 128 clicks per revolution, at about 400 RPM (i think) we have an encoder divider board, do you suggest we implement that? generally it happens when i drive fast, but not always. i have it rigged right now so that it prints 1 when the first encoder fires, and 2 when the second one fires. the last line it prints is, "----2------------"
Unread 10-02-2007, 15:38
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
...Are you printing out those inside the interrupts? If so, that's most likely your problem. printf takes too long to execute inside an interrupt.
xXx.S3nS31-h4nz0.xXx
Unread 10-02-2007, 15:39
paulcd2000's Avatar
AKA: Paul Dagnelie
Actually, i just realized: when it hits the violation, the motors were running, and the print statements were activated. What i mean is that we have a function , PrintData():
PrintData(){
	printf("\r------------------------- USER INPUTS -------------------------------\r");
	printf("Joystick 1 Y-axis: %d\t Joystick 1 Trigger: %d\r", left_joy, p1_sw_trig);
	printf("Joystick 2 Y-axis: %d\t Joystick 2 Trigger: %d\r", right_joy, p2_sw_trig);
	printf("\r------------------------- PWM OUTPUTS -------------------------------\r");
 	printf("Left Motor: %d\t Right Motor: %d\r",  (int)left_motor, (int)right_motor);
 	printf("Relay 1 Forward: %d\t Relay 1 Reverse: %d\r", relay1_fwd, relay1_rev);
 	printf("Relay 2 Forward: %d\t Relay 2 Reverse: %d\r", relay2_fwd, relay2_rev);
/*	printf("\r------------------------- SENSORS -------------------------------\r");
	printf("\r------------------------- VARIABLES -------------------------------\r");
	printf("Alt Left Encoder: %dl\t Alt Right Encoder: %dl\r", Encoder_1_Counter, Encoder_2_Counter);
i think maybe the encoders fired during the print statement, which would explain the hyphens. Do you think that could cause problems
Unread 10-02-2007, 15:40
paulcd2000's Avatar
AKA: Paul Dagnelie
i'm actually using puts("1"); which my dad said would work... could that be the problem?
Unread 10-02-2007, 15:42
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
That's a lot of clicks. I can't promise you that your problem is oversaturating the interrupts, but it's the first thing I would investigate. Plug in your divider board, and use the highest divider you can. If that eliminates the problem, you can go to finer resolution as long as it's still working. I'm sure there are other possible causes for this problem, but they would be impossible to find without seeing your code, and maybe still impossible then. In any case, try that first.
EDIT: Now that I see your latest post, you definitely shouldn't be doing anything in your interrupt handler other than incrementing a variable or something. That would be the first thing I would fix, if you are indeed doing a puts or something in there.
_
Unread 10-02-2007, 15:52
paulcd2000's Avatar
AKA: Paul Dagnelie
YAY that fixed it. thanks! I only had them cuz the encoders weren't working before, so we put prints on everything that had anything to do with it
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
GTS Code Error (the red light of doom!) Denz Programming 9 07-04-2006 17:39
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
