Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 10-02-2007, 14:50
sbf2009 sbf2009 is offline
sbf2009 is an unknown quantity at this point
Unhappy Programming a Joystick
We have a basic joystick and don't know how to program the buttons on it, could someone explain or link us to a tutorial?
P.S. Would it be legal to switch joystick ports in the middle of a competition?
Unread 10-02-2007, 15:47
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Programming a Joystick
Well, first off, what are you using EasyC or MPlab?
in MPLab, here's a sample alias: p1_sw_trig
what this means:
"p1" is the port it's plugged into
"_sw_" means it's a switch (you always need
"trig" means the trigger button. There's also "top" (which is the side button), aux1(the top left button), aux2 (the top right button), and wheel (the wheel, but i don't know what it returns)
they all return a 1 or 0 depending on whether the button is pushed or not.
For EasyC... get someone else. I have only used MPLab
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 10-02-2007, 15:55
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Smile Re: Programming a Joystick
joystick related code is delt with in user_routines.c. Each button has it's own variable. Joystick positions have two variables, 1 for the x directions and one for the y directions. The values for these positions are mapped like pwm values: 0 is full one direction, 127 means the joystick is in it's neutral position, and 255 means the joystick is being pushed as far as it goes in the other direction. Because of the nature of the values, putting the line of code:
pwm01 = p1_y;
... would be legit, because when the joystick is just sitting there, it doesn't move, and when the joystick is pushed forward/backward all the way, the motor goes as fast as it goes in the appropriate direction. This setup is a bit twitchy, because slight movements in the joystick gets responses from the motor.
Variable names are in the format *joystick_port_name*_*button/axis*.
This means p2_x is the variable dealing with the joystick plugged into the second control port, and the has to do with the x axis directions.
As for unplugging the joystick in the middle of a competion; don't. It confuses the robot, and bad things happen .
Unread 10-02-2007, 15:59
paulcd2000's Avatar
AKA: Paul Dagnelie
you can write a function to cancel out values near the middle range. we call ours, "DEADZONE":
unsigned char Deadzone(unsigned char x){
	if ( (x <= (127 + DEADZONE)) && (x >= (127 - DEADZONE)) ) // if variable is within DEADZONE, stop motor
		return STOP;
	else
		return x;
you need to #define deadzone as something, around 15-20
just implement it:
p1_y = Deadzone(p1_y);
  p1_x = Deadzone(p1_x);
  p2_y = Deadzone(p2_y);
  p2_x = Deadzone(p2_x);
  p3_y = Deadzone(p3_y);
Programming Extra Joystick Buttons Inverted Programming 2 08-02-2007 11:45
Joystick Programming team 803 Programming 6 21-02-2006 11:49
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
Programming the second joystick in PBASIC archiver 2001 2 24-06-2002 00:25
