Go to Post FIRST does have instant replay. Its called the off season. - Wayne C. [more]
Unread 10-02-2007, 14:31
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Question Problem Compiling Project
When trying to compile a project in EasyC Pro I get the following error, "C project file was not found." Anyone know what this means?
Unread 10-02-2007, 16:08
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Problem Compiling Project
Are you using a limited user account? I remember something like this happening when you don't have write access to the easyC installation directory.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 10-02-2007, 17:29
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
When you install easyC you must be an administrator.
When you unlock easyC you must be an administrator.
When you run easyC you must have read / write / change access to
C:\Program Files\Intelitek (default install dir)
Unread 10-02-2007, 17:46
Carpe diem
That's probably it. I'll have to check that out when I head back to the high school tomorrow. Thank you.
Compiling problem - suddenly Glabals.o is missing C-*P*-B Programming 3 20-01-2007 08:03
Compiling problem Anime-niac_2.9 VEX 4 19-10-2006 16:13
Very wierd compiling problem! Max Brin Programming 6 08-02-2006 15:43
compiling in MPlab Greg Needel Programming 2 16-12-2005 12:43
Problem compiling edubot Ben B Programming 3 14-01-2004 00:51
