Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 10-02-2007, 17:12
Pnakovich's Avatar
Pnakovich Pnakovich is offline
AKA: Paul Pnakovich
FRC #0612 (Chantilly Robotics)
Pnakovich has a spectacular aura aboutPnakovich has a spectacular aura about
Send a message via AIM to Pnakovich
pic: Current Robot Chasis
Unread 10-02-2007, 17:14
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: pic: Current Robot Chasis
I'm just curious:
Do you include every t-slot slide fastener in the assembly?
If so, do you constrain them one by one, or do you use iMates?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 10-02-2007, 18:37
Pnakovich's Avatar
AKA: Paul Pnakovich
there are alot but not every nut has one yet, it's mostly an assembly of a nut and slider, than i constrain each one
Unread 10-02-2007, 18:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
While quite modular, we could never afford the weight of something like that.
Unread 10-02-2007, 18:49
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
After seeing the horrors of people i know using extrustion, i cry on the inside for you. It's strong, but the weight, terrible. I mean, that looks like 25 or so pounds of metal to me, just for the frame metal
Unread 10-02-2007, 18:50
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
in fact that frame with all electronic and pneumatics and drive system and gamepiece manipulator is only 86 lbs
so its not bad if anything we need to do gain weight with our arm and ramp on as well
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 10-02-2007, 18:51
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Is that 80/20 or Bosch?
20 mm, or 30 mm?
Unread 10-02-2007, 19:01
FRC #0612
Team Role: Mascot
80/20 1 inch by 1 inch
Unread 10-02-2007, 19:57
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Ok, we had a similar 80-20 frame in 2005. I would highly suggest switching out the L- brackets in the corner for something which provides more stability.
We had the problem of the t-nuts getting loosened during matches resulting in our frame becoming warped, and even falling apart. At our first regional we were lucky enough for there to be a very nice, and very skilled welder who tacked the corners of the bot. We learned later that those L-brackets weren't really meant for holding a frame together like that.
I would suggest looking at the 80-20 catalog. They have some nice triangular plates and things which can stiffen up the frame and make it stronger
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 10-02-2007, 21:15
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
I would suggest 8020s anchor fastners.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 10-02-2007, 21:17
DonRotolo's Avatar
Back to humble
FRC #0832
I agree with Pika1579, T nuts and even L brackets will not be satisfying for you, try gusset plates at the least, or hard-connect corners with bolts. really important for areas subject to impacts, not important for other areas.
Don
Unread 12-02-2007, 07:53
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
we do have larger angle brackets on the corners, they are just not pictured in this assembly
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 13-02-2007, 16:36
edboy's Avatar
edboy edboy is offline
Plays well with others
AKA: Patrick
FRC #1261 (Robolions)
edboy is on a distinguished road
you should the the corner cube pieces, they provide a lot of stability
on the more stressed parts of the robot, you might want to change out the L brackets with the triangle gussets, they are much more stable
there are also two types of L brackets i know of, one thinner than the other
if you are using the thin ones, definitely change them, or your robot will be scrap
That match was probably one of the most amazing displays of agile mobility I have seen in a FIRST competition. We were all convinced that 1261 had
been hiding their talents up to that point, and finally decided to really show their capabilities. And when they did, was it ever impressive!
Dave Lavery
DAVE LAVERY OWNZ
Unread 13-02-2007, 17:55
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
80/20 is really nice to work with (t-nut mounting system, never have to to drill holes, etc), but I agree to the notion that it's REALLY heavy. We are using it to attach the arm to our chassis, so we can move it up/down and make adjustments super quick.
Keep in mind that the 1010 is like .5 lbs/linear foot....
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: 6 Wheel Drive Chasis AJ R Extra Discussion 5 06-01-2007 08:49
[OCCRA]: current completion of robot... BlazinFire47 OCCRA 1 06-10-2005 19:34
pic: RI Current Teams Jessica Boucher Extra Discussion 3 03-05-2005 20:03
pic: MA Teams - Current and Dormant Jessica Boucher Extra Discussion 5 30-04-2005 10:38
