Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 10-02-2007, 19:14
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Getting the camera to work in autonomous
I've now got the camera working in human operated mode but when we switch over to autonomous nothing happens. I've also included tracking.h in user_routines_fast.c, Our code currently looks something like this:
Getdata(&rxdata);
Camera_Handler();
Servo_Track();
if (Get_Tracking_State == TARGET_IN_VIEW)
      pwm13 = pwm15 = 170;
else
      pwm13 = pwm15 = 127;
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata);
I was simply trying to see if i could get the motors to respond to what the camera was seeing. Is there some reason why this isn't working?
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 10-02-2007, 19:21
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Getting the camera to work in autonomous
Kevin's camera state handler (Camera_Handler(), I believe) wants to be called in the "slow loop" (every 26.2 ms). It counts how many times it has been called to determine how long it has been to determine if a time-out condition has occurred. Make sure your code is calling Camera_Handler() only when there is new data:
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
        Camera_Handler();
        Servo_Track();
        //Add whatever code you want here.//
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Also, uncomment the #define for _DEBUG in camera.h and see what you get in the terminal window when you turn on auton. You should see either the initialization like you would in user mode, or tracking packets (that might only apply to Kevin's "Bells and Whistles" version; not sure).
JBot
Aren't signatures a bit outdated?
Unread 10-02-2007, 19:58
dpick1055's Avatar
David Pick
I have the Camera_Handler() and Servo_Track() functions where you said to put them. I am using Kevin's bells and whistles code but when i enable debugging one of motors goes full forward and one goes full reverse (but that just could be because of how we have them mounted).
Unread 10-02-2007, 20:11
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Enabling _DEBUG mode should not change how your 'bot reacts to anything (but it might; I've proven that with code, physical impossibilities become totally possible and what was extraordinary becomes a common occurance... ). Just for now, comment any code that deals with the motors during auton. Look in the terminal window and see what you get. You need to know if the camera is still getting initialized like normal. If it is, the problem is with your drive code.
My guess is that the camera is initializing fine, and as soon as it sees a target, it gives both motors 170, which, depending on your setup, motor polarity, transmissions, etc. might look like a full power spin. Try reversing one of the motors (it would be pwm15 = 84; I think).
JBot
Unread 10-02-2007, 20:25
dpick1055's Avatar
David Pick
It says Camera: Initialized abnormally with code. Unfortunatly I've had to leave our work area and won't be able to get back to the robot until monday so I won't be able to do any more testing.
Unread 10-02-2007, 20:38
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I would suggest you probably don't look at this thread until Monday--you'll drive yourself nuts between now and Monday if you keep thinking about it. However: Do you remember what code it was? Was it 131? That's the common timeout code. Why it would occur in auton and not in user mode baffles me; I hope Kevin Watson sees this and responds. His posts are usually better than mine.
JBot
Unread 10-02-2007, 20:54
Yes, there is a reason. Kevin didn't modify the autonomous function to use the interrupt-based PWM generation he included with the camera code. You need to replace the Generate_Pwms() call with PWM(pwm13,pwm14,pwm15,pwm16) instead.
Unread 10-02-2007, 20:56
dpick1055's Avatar
David Pick
Sorry I don't remeber what the code was. Though would you get a timeout error if the camera never starts searching?
Unread 10-02-2007, 20:57
dpick1055's Avatar
David Pick
When I first started playing with autonomous I just sent the motors full forward which only worked with generate_pwms and not PWM.
Getting the Camera out of Idle Eclipse Programming 2 13-02-2007 04:06
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
even simple autonomous code doesn't work?? colman77 Programming 4 17-02-2006 23:58
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Anyone get Autonomous mode to work? Larry Barello Control System 4 13-01-2004 15:15
