Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Unread 10-02-2007, 20:31
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
Re: Crate problems
Since the forklift needs at least that space to get under the crate to lift it up, I wouldn't change anything. But, what you could do is put an extra piece of plywood in their, whether loose or on hinges, to act as a ramp for an easy way to get it out of the crate, if you are able to do that.
Remember, you will still have to lift your robot on and off of your cart so if your trying to avoid that, it's kind of hard to.
Just trying to help out! XD
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Crate Question Gamer930 General Forum 2 11-01-2003 12:30
CRATE WEIGHT!!!!!!!! archiver 2001 1 24-06-2002 01:03
Crate RBrandy General Forum 1 06-02-2002 20:59
Crate question DanL Technical Discussion 1 02-02-2002 16:41
