Go to Post Volunteer...it will make you see a totally different side of FIRST. - Collin Fultz [more]
Unread 10-02-2007, 12:24
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Crate problems
Hey all,
We are building our crate for the first time this year and ran into a bit of a snag. We are wanting to notch the 4X4's that the crate "sits" on but we were wondering if this is allowed. The rules say our crate must sit on a pair of 4X4's but doesn't say if we can have a lower ground clearance. Is this allowed?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 10-02-2007, 12:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Crate problems
It probably would not be a good idea, the purpose of the 4x4s is to allow room for a forklift to get under the crate and lift it.
Unread 10-02-2007, 12:33
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
Re: Crate problems
I am not sure why you would want lower ground clearance. The 4x4 is not 4" and the crates are moved by fork lifts. Over the past nine years we have always used 4x4's and have never had a problem.
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
Unread 10-02-2007, 12:41
Typer of doom
AKA: Chris McKenzie
Re: Crate problems
We were going to put 2X4's in the notches to support the bottom of the bot.
Chris
battles."
Unread 10-02-2007, 13:44
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Crate problems
Chris
I wouldn't leave any holes in the bottom. You don't want a stray forklift spearing the bottom of your bot.
4x4, then a sheet of ply, then rails on top so the bot doesn't ship on it's wheels.
Unread 10-02-2007, 15:05
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Re: Crate problems
Since a 4x4 is really 3.25 inches I would make sure you have 3.25 inches of clearance at all points under the base of your crate except where the 4x4 touches floor. If you want to add a 2x4 to support robot under floor of crate and would also add a 2x4 to the 4x4. Take it from some one has driven a forklift for about 30 years. You want as much clearance under crate as possible.
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 10-02-2007, 20:31
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
Re: Crate problems
Since the forklift needs at least that space to get under the crate to lift it up, I wouldn't change anything. But, what you could do is put an extra piece of plywood in their, whether loose or on hinges, to act as a ramp for an easy way to get it out of the crate, if you are able to do that.
Remember, you will still have to lift your robot on and off of your cart so if your trying to avoid that, it's kind of hard to.
Just trying to help out! XD
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Crate Question Gamer930 General Forum 2 11-01-2003 12:30
CRATE WEIGHT!!!!!!!! archiver 2001 1 24-06-2002 01:03
Crate RBrandy General Forum 1 06-02-2002 20:59
Crate question DanL Technical Discussion 1 02-02-2002 16:41
