Go to Post Dean's never ending fountain of denim. - kjolana1124 [more]
Unread 10-02-2007, 20:38
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Getting the camera to work in autonomous
Originally Posted by dpick1055 View Post
It says Camera: Initialized abnormally with code. Unfortunatly I've had to leave our work area and won't be able to get back to the robot until monday so I won't be able to do any more testing.
I would suggest you probably don't look at this thread until Monday--you'll drive yourself nuts between now and Monday if you keep thinking about it. However: Do you remember what code it was? Was it 131? That's the common timeout code. Why it would occur in auton and not in user mode baffles me; I hope Kevin Watson sees this and responds. His posts are usually better than mine.
JBot
Aren't signatures a bit outdated?
Getting the Camera out of Idle Eclipse Programming 2 13-02-2007 04:06
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
even simple autonomous code doesn't work?? colman77 Programming 4 17-02-2006 23:58
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Anyone get Autonomous mode to work? Larry Barello Control System 4 13-01-2004 15:15
