Go to Post (If Dean still says 'Nationals', how can you ridicule a rookie team for it? Come on.) - Amanda Morrison [more]
Unread 11-02-2007, 00:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Development on OS X
Eclipse will run MCC18, with help of the CDT. If you use a makefile, stock will do. FIRSTclipse provides plugins for managed make. The error parser won't work on non-windows, though, since it doesn't do any path translation.
Running MCC18, though, is slightly more challenging. (Disclaimer: I don't own a mac, so this is gathered.)
He's the scenarios I've found from reading:
  • PPC: Good luck. No native/inline emulators seem to be available.
  • Mac OS X86: It's BSD Unix. Use wine (or some variant) and follow the Linux instructions
  • Bootcamp: Load windows, handle everything normally.
A more pressing problem with Mac may be the lack of RS-232. OS X can handle USB-Serial adaptors, IIRC. Classic Mac might have problems, since Apple used its own spec which is not pin-compatible with RS-232.
Eclipse Development Astronouth7303 Programming 39 16-12-2007 02:52
Development daramana Inventor 1 03-03-2005 08:07
Software Development Process? tcj103 Programming 5 08-02-2005 15:46
Website development tchescow Website Design/Showcase 3 31-12-2004 17:13
Development Program xxlshortys Team Organization 1 14-03-2004 12:33
