Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 11-02-2007, 01:20
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Re: How do I program this sensor?
This is what I have now:
void Default_Routine(void)
 	int count = 0;
	int now;
	int last;
	now = last;
	rc_dig_in04 = now;
blah blah blah..map joysticks..
                  * Sensor Code *
 	if((pwm03 < 125) || (pwm03 > 129))
 		if((now == 1) && (last == 0)) //If sensor, which connects to Dig In/Out port 4, goes off...
			count++; //Number of times tape passes through the sensor.
			Switch1_LED = 1; //Switch01 goes on when the tape passes the sensor.
		else
			Switch1_LED = 0;
		if(count == 8)
			Relay2_green = 0;
			Relay2_red = 0;
			pwm03 = 127; //Motor stops when it retreats to ground level.
			count = 0;
		else if(count == 7)
			Relay2_green = 0;
			Relay2_red = 1;
			pwm03 = 127; //Motor stops when it retreats to 1st level.
		else if(count == 6)
			Relay2_green = 0;
			Relay2_red = 1;
			pwm03 = 127; //Motor stops when it retreats to 2nd level.
		else if(count == 5)
			Relay2_green = 0;
			Relay2_red = 1;
			//pwm03 does not equal 127 because it must pass the tape in order to go beneath the top level.
		else if(count == 4)
			Relay2_green = 1;
			Relay2_red = 1;
			pwm03 = 127; //Motor stops when it reaches top level.
		else if(count == 3)
			Relay2_green = 1;
			Relay2_red = 0;
			pwm03 = 127; //Motor stops when it reaches 2nd level.
		else if(count == 2)
			Relay2_green = 1;
			Relay2_red = 0;
			pwm03 = 127; //Motor stops when it reaches 1st level.
		//if count == 1 then that just means that it passed through the first piece of tape which will be used to show that it is in full DOWN position.
So I have yet to make the switch statement, but I made some changes. Do you understand yet what I am trying to do with the forklift Kevin? (Any other thoughts also) Thank you guys so much. You're saving my team of 5.
Vex line follower sensor kit program jbill30 Programming 5 12-05-2006 14:43
What's happening to this program??? Weightmn General Forum 22 04-04-2005 15:40
TI Pressure Sensor this year? kmcclary Pneumatics 1 20-01-2005 20:53
This board is quiet-- so how bout this election?!?!? archiver 2000 19 24-06-2002 00:23
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
