Go to Post It's better to be safe than sorry. - Dan Petrovic [more]
Unread 11-02-2007, 10:00
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: Chicklet-issues
Originally Posted by mattg101 View Post
I believe I have a usb-chicklet problem. I am using the logitech 3d extreme, p/n 863225-1000. For some reason I am not getting correct pwm values outputting to the robot. When I pull back on the y-axis, I am getting different pwm values for pwms which should be the same. When I push forward on the y-axis everything is ok. This problem only occurs on the y and r axises. I have gone through the calibration mode twice with not difficulty. When I use a analog joystick without the usb-chicklet I have not problems. I just bought to logitech joystick 2 weeks ago. Any suggestions?
Have you checked to make sure that the PWM's are in the right spot? We had this problem this year. "If the program fails, its the mechanical side. If the mechanical side fails, check the program. If they both fail, find someone to blame"
Min-Max to the Max!
Unread 11-02-2007, 13:09
354.FIRST 354.FIRST is offline
FRC #0354
354.FIRST is an unknown quantity at this point
Re: Chicklet-issues
You can also try to see if your speed controller is having problems. We had a similar problem and when we swapped out the speed controller it all worked fine.
good luck
-354
Visit our website at GWestRobotics.Com
Unread 17-02-2008, 14:55
Trav-O's Avatar
Trav-O Trav-O is offline
THE PROGRAMINATOR
AKA: Travis
FRC #0510 (Hawaii 5-1-0)
Team Role: Tactician
Trav-O is infamous around these partsTrav-O is infamous around these parts
Re: Chicklet-issues
we had the same problem. Turns out i accidentally was hitting the trigger while calibrating the axises... be carful and take things slooow... it works
Be safe!!! OR YOU MIGHT GET INJURIES!
Unread 18-02-2008, 21:09
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Chicklet-issues
also, check your power supply. when we used a battery, and it was low, the chicklet would spit out insane values.
Unread 19-02-2008, 11:07
WaterFreak WaterFreak is offline
FRC #0708 (Hardwired Fusion)
WaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to behold
Re: Chicklet-issues
When attacking a problem LIKE this, always use an analytical approach, will save you gray hair and high blood pressure.
#1 Check the values being reported by the joystick, using the dashboard (as per the procedure mentioned here). You should be able to SEE the values being reported by the joystick. If they are off, go back and try the calibration process again and repeat Step #1 before proceeding.
#2 Check the values at multiple steps INSIDE your code. Where are they read in? Where are they manipulated? Where are they written out? Ensure that you are operating on the right INPUT values and setting the right OUTPUT values. Are the outputs getting overwritten AFTER you write them? Search ALL the code for potential issues and examine your code flow.
#3 Use the dashboard again, but now in the RC mode to ensure that the values are being received and set at the RC output.
#4 Make sure you have the PWM cables plugged into the right things at BOTH ends of the cable.
#5 Check your electrical connections at the Vic/Spike. Loose connections make for erratic behavior.
I have done a LOT of programming and validation with just a OI & RC hooked up with some power. Seems the programmers never get to touch the real robot until the last minute
Thanks, Jim Orr
Senior Software Engineer - Motorola, Connected Home
Supporting Team 708 - Hardwired Fusion
CHICKLET PROBLEM!! T3_1565 Control System 1 10-02-2007 09:46
Chicklet Help haywirerobotics Programming 5 06-02-2007 08:12
USB Chicklet SleeveofWizard Control System 11 28-01-2007 22:45
chicklet carbuff Control System 1 27-01-2007 13:51
Fried chicklet karin l. Control System 5 24-01-2007 00:07
