Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Unread 11-02-2007, 09:19
Shomron1690 Shomron1690 is offline
FRC #1690
Shomron1690 is an unknown quantity at this point
Compressor and The Presser Switch
Do we have to put the compressor on the robot although we are not using the presser switch?
Thanks.
Unread 11-02-2007, 11:12
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Compressor and The Presser Switch
The pneumatic system rules should be read and followed, they explain exactly what must be used and what can be left off.
Don
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
