Go to Post Why is it considered shameful to do the smart thing? As the saying goes, "I don't make the rules, I just live by them." - Chris Hibner [more]
Unread 11-02-2007, 11:03
supertetelmanma supertetelmanma is offline
FRC #0501
supertetelmanma is an unknown quantity at this point
Need help making water
can someone help me out with making some water , all i need to do to finish our animation is make a flowing stream of water, but i have no idea how to.... i really would apprecdiate some help!!
Unread 11-02-2007, 13:59
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: Need help making water
For rivers, streams, creeks, etc. you can make a plane, give it a noise displacement map, and animate the offset of the map to make it "flow."
For faucets, pouring water, etc. you can try Blobmesh, but it's tricky.
Unread 11-02-2007, 17:03
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
A stream of water can be made with particle flow/spray particles (if you don't know how to use particle flow)
I think you are a bit late, because you will discover that it's a lot of render time for raytraced particles... But if you want to get a good water...
Water is basically transparent, 75% refractive and 50% reflexive (we're talking about pure water)... These are the configurations you should use (well, I do use it =p) with your raytraced material. Remember that a reflexive/refractive material need an environment to reflect/refract, and if you haven't got one, you should fill the "environment" slot of your material with an HDRI map.
Then to make a flow, you need to set up a particle emitter: super spray may work, but if you want to get more flexibility, use particle flow. I recommend you to look for a tutorial with google, because I need images to get further explanation.
Good luck with it =P
Unread 11-02-2007, 19:42
FRC #1720
You didn't say anything about what kind of water you want. There are so many different ways to make water.
Help - Making the autonomous mode razer Programming 5 31-01-2007 16:25
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! cdennisxlx2 LabView and Data Acquisition 2 21-03-2006 21:50
Making a Dongle - Pin 1 help DanL Electrical 6 05-03-2003 16:58
I need help w/ making an Invitational Matt Attallah General Forum 6 14-05-2002 19:48
