Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Unread 10-02-2007, 18:30
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
pic: 1712 CAD model of electronics
Unread 10-02-2007, 18:31
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: pic: 1712 CAD model of electronics
wow that looks really nice
electronics boards always look so good until the wires get on
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 10-02-2007, 23:24
in between teams
AKA: Luke Van Oort
I'm a bit worried about the position of that robot controller, does it meet the visibility requirements?
Team 1219: 2009 - Mentor
Unread 10-02-2007, 23:47
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
It seams that there is a large chunk of unused clear lexan/plexi/whatever above the brain, so visibility requirements should be met just fine.
Looks good!
Unread 10-02-2007, 23:55
7
FRC #1712 (Dawgma)
If it's only the lights that have to be visible, I think it's fine. I'll remind the electrical group about that.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 11-02-2007, 00:08
On the same note as the RC Light visibility issue, is the main breaker accessible enough? To me, it would seem that since the breaker is under a sheet of lexan, it is not easily accessible.
Other than that, nice board.
Unread 11-02-2007, 00:17
in between teams
AKA: Luke Van Oort
Well, thats really only half of the issue. Making the lights visible is pretty easy, the problem is that they have to be visible from three feet in front of the robot. Depending on your configuration this can be easy or hard, for us this was a problem, as we have a wide turreted arm that stows over the rear and rotates to the front for play, causing some issues. (ie. we had to mount the controller sideways, at an angle and must start on the left side of the field) Luckily, we are behind schedule, so there wasn't a lot on the robot to get in the way of changing the mounting.
Unread 11-02-2007, 14:49
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Thumbs up Re: pic: 1712 CAD model of electronics
worldbringer, You never disappoint. I can't wait to see the rest of your robot when you get done with it. How much time did it take?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 11-02-2007, 20:16
7
FRC #1712 (Dawgma)
Heh, that's nice to hear.
It's hard to say because the Inventor group doesn't work continuously every day, as we're all involved with other aspects of the team, but this probably took a couple days. The only parts we modeled from scratch were the backup battery and the lexan, and the rest were available online (Autodesk Virtual KOP, FIRST CAD Library, and the Vex Inventor model library at Carnegie Mellon).
Unread 11-02-2007, 20:46
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Looks really good in CAD you guys....great job!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 11-02-2007, 23:56
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Last year we ran into the visibility problem. They said it needed to be easily seen and easily accessible. At the competition we ended up cuting the chunk of lexan out, proping it up, and just having it somewhat sitting over everything.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Anyone have a 3d CAD model of a 2 liter soda bottle? Elgin Clock SolidWorks 14 09-09-2007 23:32
pic: Dawgma 1712 as of 1-15-07 Chuck Glick Extra Discussion 14 03-02-2007 12:43
pic: Team 356...Full CAD model CD47-Bot Robot Showcase 2 04-03-2004 08:08
Van Door CAD Model Jim Giacchi Inventor 2 04-12-2003 00:40
New CAD Model posted Ed Sparks General Forum 1 18-01-2002 17:47
