Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 11-02-2007, 16:03
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
Camera Video out
Hi Everybody,
I was just looking at the diagram of the camera and all of its outputs (http://kevin.org/frc/camera/first_cm...revision_a.jpg) and i saw the Video out header in the top left corner. Can you hook this up to an RCA cable and hook it up into a TV? If not, what can it be used for?
Thanks
Unread 11-02-2007, 17:43
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Camera Video out
Yes, you can.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 11-02-2007, 21:02
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Does anyone know if the video out header shows the full field of view that the camera sees?
I've a number of about a 60* field of view floating around, and the camera seems to have a roughly 2:1 aspect ratio, but the video we get on our TV isn't black barred or black boxed or whatever it's called (like when you watch a DVD on a regular TV).
Unread 11-02-2007, 22:07
Note that the output from that connector does not include color. It's a simple black & white video signal.
Unread 11-02-2007, 22:24
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Who said the pixels were square?
Unread 13-02-2007, 22:41
AKA: Robinson Levin
So the video is the whole image that the sensor picks up, upsampled to 640x480?
Unread 15-02-2007, 15:47
Cool, thanks for all the response, i'll be sure to try this out tonight!
Unread 15-02-2007, 15:50
I'm not sure that 'upsampled to 640x480' is as correct as "converted to NTSC". Depending what camera module you have, you either get an NTSC signal or a PAL signal, and since they are strictly analog they don't really have pixels.
Unread 15-02-2007, 22:27
It's a close approximation to NTSC or PAL, anyway. And its modulation is digital enough to make talking about pixels reasonable.
Unread 15-02-2007, 22:32
AKA: Robinson Levin
And after all this, the answer to the question itself is what?
So the video is the whole image that the sensor picks up?
Thanks in advance,
Robinson
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Getting the Camera out of Idle Eclipse Programming 2 13-02-2007 04:06
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Camera Freaking Out adodge Programming 2 26-01-2006 21:13
Using camera PWM out Cuog Programming 2 28-11-2005 14:17
